20 Most Recent E-Machines E17T4 LCD Monitor Questions & Answers
2answers
Monitor show picture for a few seconds, then turns black
It sounds like the power supply board on your monitor is failing. If it's still under warranty you might be able to get a replacement from the manufacturer - if not, you might be able to have it repaired at a computer or TV repair shop.
1/21/2013 2:13:24 PM • E-Machines E17T4... • Answered on Jan 21, 2013
2answers
Standby Mode
yes it saves power.
11/7/2011 6:42:22 PM • E-Machines E17T4... • Answered on Nov 07, 2011
Down the left hand side
Assuming that you have tried the monitor on a different computer and that the pins on the VGA lead show no damage or signs of looseness and that the vga lead is a good fit in the socket, the probable answer is that the monitor is starting to fail. Eventually, the lines will increase in size, or in number and will be more visible. Repairs are usually not worth the cost of buying a replacement monitor instead. My advise is that if you can live with it, thendo so until you decide to get a replacement.
7/15/2011 10:48:26 PM • E-Machines E17T4... • Answered on Jul 15, 2011
2answers
Power light just keeps flashing blue it won't turn
rpwest51, Monitor internal "switch-mode-power-supply could be in what is known as "shutdown immediate" mode having sensed (detected) a fault condition with itself or the inverter lamp high voltage supply. You or qualified technician will need to investigate unit to determine root cause down to component level and decide if unit is viable candidate for cheap DIY ($8 parts cost) fix. Above all else, remember this! Your "cold-cathode-fluorescent-lamp" back-lit LCD monitor is no different than any other brand in it's basic design and operation. If you do your research you will also have a good idea as to how those new style curlie-Q energy efficient screw-in CFL ight bulbs work.Read through my higher numbered fixya profile pages and those of other CCFL lcd monitor techs profiles and follow the links you find there for all options that you may have. Hope this helps. 12fixlouie
4/14/2010 4:21:29 AM • E-Machines E17T4... • Answered on Apr 14, 2010
My monitor goes blank. it comes back after i have
Check for bad caps in the power supply first, look for caps with ulging top, post back what you see so we can guide you further, see example of failed monitors due to badc caps: http://s807.photobucket.com/home/budm/allalbums
2/17/2010 6:58:55 PM • E-Machines E17T4... • Answered on Feb 17, 2010
2answers
I upgraded my windows 2000 desktop from a crt
If you use windows 2000 that means it is a Old PC and today's LCD or flat panel monitors require a little bit advanced graphics card than the cards or chip which is used with windows 2000 PCs so please buy a compatible graphics card for your PC from any local shop which will support the resolution of your new monitor and enjoy the clear graphics.
2/15/2010 6:21:03 AM • E-Machines E17T4... • Answered on Feb 15, 2010
0answers
What is the optimal resolution setting for this
According to the manufacturer's web-site:
http://www.emachines.com/support/product_support.html?cat=Monitors&subcat=Flat%20Panel&model=E17T4W
the maximum resolution is 1280x1024.
11/6/2009 7:18:06 PM • E-Machines E17T4... • Answered on Nov 06, 2009
My monotor only shows half a screen
Ya half a screen sound like monitor is dying. No point of fixing it.. well cost you more to fix then to buy a new one.
9/13/2009 11:09:11 PM • E-Machines E17T4... • Answered on Sep 13, 2009
My monitor randomly turns off.
Most likely you have a bad INVERTER BOARD.
2nd in line is a burned out backlight fluorescent bulb.
7/2/2009 11:30:56 PM • E-Machines E17T4... • Answered on Jul 02, 2009
E17T4 monitor won't turn on
It could certainly be a fuse inside the monitor, although it's more likely to be an electrolytic capacitor. These kinds of repairs are possible but only by a skilled technician - with the right tools and knowledge. If your monitor is still under warranty, I recommend returning it to the manufacturer. If not, a TV or computer repair shop might be able to repair it, but it will probably be rather expensive.
The problem is probably localized in the monitor's power supply board, and a possible fix is to replace that board. If you can find another one you might be able to replace it and repair the monitor - but finding one might be difficult.
6/10/2008 10:37:13 PM • E-Machines E17T4... • Answered on Jun 10, 2008
I have an eView 17f3 computer monitor that was
well that is 17,000 volts there 17kv and can be lethal . CRT is cathode ray tube and 2nd anode is 17kv, 1kv per inch screen.. we use a chicken stick to discharge that. one guy gut hit here and flew across the room ,hit head and next up paramedics deep.. not fun to see that. ive taking 600v but never again. vaccum seal, why do that.??? send it to the , toxic lead recycle center, let them do the danger work when I was only 16yo I worked in TV shop and I had do that "nnipp" that in the bud on all CRT sent off to refurb. (or toxic trash) (we sold them all here, you name it) we had to remove the socket there find he glass bud there dead center and full PPE, and snap it with wire cutters and it sucks in air fast. later in military too on old radar scopes, i worked . the vacuum inside is pure and prefect, zero gasses. implosion hazard exists. a glass flies in the bounces out and hits you and then next up blind i one eye. leave CRT alone to the trained.
5/16/2022 5:02:25 PM • E-Machines... • Answered on May 16, 2022
No power to E17T4 monitor
the monitor is dead. PSU dead inside. only used PSU sold on ebay.
5/16/2022 4:06:15 PM • E-Machines... • Answered on May 16, 2022
CPU fell on floor now windows won't load. How can I tell if he'd is hosed or can be fixed?
to boot a cd then you must have the bios set to allow it, or tap f12 immediately to intercept boot menu and choose cd. sounds like your drive has a few bad disk sectors.
1/16/2019 1:40:50 PM • E-Machines... • Answered on Jan 16, 2019
Hi i have emachine 8230 tower
firstly lets think why a Working pc would no longer BOOT. The boot process then. a pc starts the bios which POST's. this results in ONE BEEP which might be followed by messages(if you get several beeps then they are like morse code long/short and count out an error code). when you get your ONE BEEP the pc is working. when it then HANGS(appears to do nothing) its usually because of either a) the cd drive is duff so disconnect its cables. b) the hard drive is duff so disconnect its cables c) the hard drive hasnt quite died yet but has some very slow sectors and is making the Clackety Clack of the heads recalibrating every few seconds. d) there could be a a gpu card bios glitch and your pc is running but you just have a blank screen. some hints then 1) never start removing parts as that corrupts the CMOS(the battery backed up configuration for your BIOS) so you may need to clear your cmos. 2) never play with the idea of changing ram sticks as people usually end up putting them in any old slot(which may result in a non working pc). make sure a PAIR is fitted in slots 0/2 and a separate matching pair in 1/3 slots not in slots 0/1 which is two half pairs. Other factors. 1) a short circuit. your PSU has built in protection, if the psu fan(inside case of the psu) turns and kicks back and immediately stops you have a short circuit and its cuts the power to avoid a fire/meltdown, which could be caused by high wattage gpu(>60 watts) without its extra power cables fitted or wrongly connected front usb cables or removing a mainboard and fitting it into a new box where the board has its support posts NOT lined up with the holes fro the screws so the post is touching underside of the board circuits. hope some of that helps.
11/22/2018 8:38:26 AM • E-Machines... • Answered on Nov 22, 2018
0answers
0answers
E-Machines E17T4 LCD Monitor Logo
25 questions posted
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • E-Machines Computers & Internet
Most Popular Question
  • Computers & Internet
