20 Most Recent Vizio P50HDTV10A 50 in. Plasma HDTV Questions & Answers
Not if the main processor board or display is faulty.
Vizio P50HDTV10A... | Answered on Jan 20, 2018
Reset Vizio TV default:
1. Press the MENU button on the remote. The on-screen menu is displayed.
2. Use the Arrow buttons on the remote to highlight the Help icon and press OK. The Help menu is displayed.
3. Highlight Clear Memory (Factory Default) and press OK.
4. Enter your parental control passcode. If you have not yet set up a parental passcode, enter the default, 0000.The TV displays, "Are you sure you would like to Restore Defaults? This will erase any custom settings."
5. Highlight Yes and press OK. The TV displays "Memory is being cleared. The TV will reset shortly."
6. Wait for the TV to turn off. The TV will turn back on shortly afterward and the Setup App will begin.
Vizio P50HDTV10A... | Answered on Jan 16, 2018
Try replacing the Tcon board
Vizio P50HDTV10A... | Answered on Dec 23, 2017
Good day sir Thor!!!!
I already encounter that kind of problem many times..It looks like all normal even the green power light is not blinks or change to red or amber color but still no sounds or picture on TV..
Sometimes it will happen to plasma TV in all brands and model..It cause of faulty main board..
This is the sample picture of main board of your unit..Part # (3850-0142-0150)
You can order this parts here:
http://premiertvparts.com/index.php?main_page=product_info&cPath=1&products_id=797
http://www.ebay.com/itm/NEW-VIZIO-VP50-HDTV20A-MAIN-UNIT-3850-0142-0150-2A-/320737894046
http://tvpartsfast.ecrater.com/p/12695612/vizio-3850-0142-0150-main-board-for-vp50hdtv20a
http://modulesrus.ecrater.com/p/11497716/vizio-main-a-v-3850-0142-0150
Just replace the board to fix your TV and it works again..
Note: When you install the board make it sure that the static energy on your body discharge to ground to avoid corrupt of main board IC..
EXAMPLE: open the cover then find the main board..before you do that make it sure you hold the metal portion of your TV to discharge static after that you can now freely replace the board and also make it sure to memorized the connector to avoid damage to make it sure take a picture on it before unplug connector for future reference in case..
again discharge static please!!!..Only few tech or other people know this that's why when they install new boards its not works even it is new..I discover this base on my experience and study..
Hope it helps..
Please don't forget to rate!!!!
Thank you using fixya..
Vizio P50HDTV10A... | Answered on Nov 17, 2017
If there is no auto dimmer on the TV, than the TV needs professional repair work.
Vizio P50HDTV10A... | Answered on Nov 14, 2017
Open it up and locate the source of the clicking. Chances are that is the defective board in your set.
TV Parts Universal TV Stands DLP Chips ShopJimmy
Vizio P50HDTV10A... | Answered on Sep 21, 2017
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Vizio P50HDTV10A... | Answered on Jul 06, 2017
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Vizio P50HDTV10A... | Answered on Mar 05, 2017
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
622 questions posted
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vizio Televison & Video
Most Popular Question
vizio p50hdtv10a hdtv whole screen black
  • Televison & Video
