20 Most Recent Panasonic Lumix DMC-FX3 Digital Camera Questions & Answers
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Panasonic Lumix ... | Answered on Oct 06, 2014
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto.
Panasonic Lumix ... | Answered on Oct 04, 2014
if you got usb lead with it just plug into computer n it installs it
Panasonic Lumix ... | Answered on Jul 21, 2014
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Panasonic Lumix ... | Answered on May 19, 2014
Do you really need a driver?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Panasonic Lumix ... | Answered on Apr 29, 2014
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo management program.
Panasonic Lumix ... | Answered on Apr 15, 2014
i can tell you that the lcd backlight is working but the lcd is definetly damaged. if you can find it in you to purchase the lcd and fit it yourself then you could fit it yourself. if it becomes difficult then get a technician to fit it.
Panasonic Lumix ... | Answered on Jan 12, 2014
Panasonic Lumix ... | Answered on Feb 10, 2013
You may download a copy of the manual from here.
Panasonic Lumix ... | Answered on Aug 25, 2012
You don't need any special software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Panasonic Lumix ... | Answered on Jul 01, 2012
You can download the manual here.
Panasonic Lumix ... | Answered on Oct 12, 2011
Hello SugarAlmonds,
If by that you mean some pictures are OK and some are blank/no image available... that usually happens when the pictures have been edited (could be accidentally by rotating it while viewing it) in a computer OR the pictures are not properly deleted. So, when viewing pictures from your camera to your computer, it is always better to copy all of them first to your computer then you can view/edit the copied files.
To correct the problem, copy ALL the pictures to your computer and then format your memory card using your camera.
Note: all pictures on your memory card will be deleted when you format it.
I hope this helped you.
-damneddle
Panasonic Lumix ... | Answered on Oct 11, 2011
Here is a tip that I wrote about how to find the manuals, drivers, downloads andsupport for Digital Cameras.
DigitalCamera Manuals, Drivers, Downloads, and SupportHow to easilydownload Pictures from Digital Camera
heatman101
Panasonic Lumix ... | Answered on Sep 14, 2011
heatman101
Panasonic Lumix ... | Answered on Aug 24, 2011
Panasonic Lumix  DMC-FX3 Digital Camera Logo
119 questions posted
Top Panasonic Cameras Experts
Ekse
Tom Chichester
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
View Most Popular
Lumix Panasonic
  • Lumix Panasonic
Most Popular Question
date time stamp photos lumix dmc fx3
  • Cameras
