20 Most Recent
Dell 1815dn All-In-One Laser Printer Questions & Answers
Paper jam ,no paper jam found Dell 1815dn
give this a try
- Turn off the printer.
- Remove any paper trays. Inspect them for wrinkled or damaged paper.
- Also open the back cover of the printer if this model has one.
- Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
- If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
- If you find a piece of jammed paper, remove it by
holding it with both hands and pulling firmly. The goal is to keep the
paper from tearing. If several pieces are jammed together, try pulling
out the middle piece first to loosen the jam.
- If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do
this step especially if the jam message comes up repeatedly without any
obvious paper jam, there may be a small tear of paper inside.
- Ones the printer is free of paper Replace the toner or
ink cartridge and paper trays, close any doors you opened and turn the
printer back on.
- If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
- see alternative if the problem is still not solved.
alternative :
Load
a piece of thick paper, for example photo paper and press the resume
button (may be diffrent button on diffrent models) a few times to the
printer picks up the paper and puts it through the machine.
Dell Laser MFP 1815 wont print
The printer status showing offline is more then likely a computer issue then the printer. On the printer, use the menu to select "reports" and then select the printer settings report. If the printer prints the report, then the printer itself is working, and it is a communication issue between the printer and the computer. If you are connecting to the printer with a usb cable, then try moving the usb cable on the computer to another port. If this does not work, try deleting and reinstalling the printer.
I have a Dell Laser
The old stand by, unplug, wait 1 min., plug it back in. This will reboot it and may fix it.
Can send but not receive faxes. dell 1815 dn
Did you check the "answer call after x rings" option?
It sometimes defaults to 7 rings, at which time the sending fax machine has given up already.
You find the settings here: "Fax -> Fax Defaults -> Rings to answer"
If this solved your problem - great!...If not, just come back and leave a comment - I'm happy to help.
Dell laser mfp 1815 dn "scanner locked" message
When you lift the scanner lid look to the left bottom. you should see a green slider button. If you stick your hand in the output tray and get it rigth under the green slider you will find a lever. Move that thing backwards or forwards, that is your unlocker.
How to Determine the Printer
Press the scroll button <--- highlight menu,
select (checkmark)
scroll to Reports, select
scroll to system data, select
Print out will contain the page count
Why is my dell 713w showing it is not connected to the wireless network?
This situation has happened to my HP printer. The way that I fixed the problem was to connect the usb cable, then trough the printer software on the computer while computer was connected to the wireless, the printer detected the network through usb cable. Sometimes it takes may be about 15 minutes that my printer detects the network, so I have noticed that I have to give a time to it, because it searches, and searches, and it takes some times.I recommend that you leave the printer on for at least 30 minutes. Check to see that printer detects any other neighbor networks at all, because the network card on the printer may be malfunctioning, and not detecting any network at all. If you can connect your printer to a laptop or a desktop with usb cable and use any software that comes with your printer, it should have the (connect to the wireless ) software facility.That facility will then ask you for your password and it will the set up the printer wirelessly.It is like starting all over again that has happened to me also. I wonder if Dell support can assist you or not, but they should , since they built the printer.Hope all things go well with you.
1815dn printing is faded
IF this is a high use printer, there are some other things that might be in need of attention. There is a corona wire, drum and drum wiper that are consumables too.
Where is the fuser
I am not a tech person by any stretch of the imagination but if it's the thing I had so much trouble finding I can tell you.
Put your hand into the area where the printed page comes out , feel along the "ceiling" of this area (mine was in the mid-front, left hand corner). There is a little toggle-type tab. Flip it the other way & try to print again.
Good Luck!!!!!!!
