1st step - print a self test report
Press and hold the OK button. Then press the left arrow key one time.
Release the OK button.
The test page prints
OR
Press the OK and Help keys simultaneously.
print the test pages 4 time minimum
2nd step - reset the printer
If the printer is not off, press the Power button to turn it off.
Unplug the power cord from the wall outlet.
Unplug the power cord from the back of the printer.
Unplug the universal serial bus (USB) cable from the back of the printer, if connected.
Wait 30 seconds, then plug the power cord back into the printer.
Plug the power cord back into the wall outlet.
Press the Power button to turn the printer on.
Ensure that the memory card has been removed from the memory card slot.
Make sure plain paper is loaded in the In Tray.
Hold down the OK button and press the Right arrow button four times.
If the test page prints, re-connect the USB cable to the printer.
OR IF YOU ARE NOT ABLE TO DO SO THEN
start - printers & faxes - click on the printer icon highlighted with a correct symbol ( ensure the proper printer is highlighted )- right click on the icon - properties - print test page option at the bottom of the properties screen.
3rd step - if the USB is connected to a USB Hub then disconnect it from the HUB and connect it directly to the wall socket.Make sure the USB cord is of the proper measurement as mentioned for the printer in the User Manual.
4th step - visit www.hp.com
left side of the screen you shall see an option SOFTWARE & DRIVERS DOWNLOAD
click on that
in the next screen a tab comes up mentioning FOR PRODUCT
enter PHOTOSMART D 5160 and hit enter / click on the arrow beside it
choose the OS
under DRIVER YOU HAVE OPTIONS LIKE -
» HP Basic Driver (recommended)
» HP Full Software and Driver (before downloading it uninstall the s/w & then download it )-DO THIS ONLY IF THE 1ST OPTION DOES NOT MAKE THE PRINTER FUNCTION FINE
STILL ERROR PERSISTS : - replace if under warranty/service the printer in the service centre
Salve La stampante Photosmart HP D5160 dopo l'accensione inizia a produrre rumori come ingranaggi che si graffiano ripetutamente nell'area vicino al cassetto di sostituzione delle cartucce, alla fine dopo alcuni istanti la stampante smette di fare rumore ed ? pronta per la stampa, ma ultimamente, dopo sopra, sistematicamente non viene pi? stampato e il punto esclamativo rosso lampeggiante rimane. Le cartucce sono originali e hanno una capacit? superiore ai 3/4. Spero in tuo aiuto il prima possibile. Grazie. Roberta
You can download the Softwares/Drivers for your printer from these links (similar with the contents on the Hp CD) :
Hp Photosmart D5160 Printer for windows xp 32 bit
or
ftp://ftp.hp.com/pub/softlib/software10/COL15834/dj-41864-2/TF_regna_psp_NB.exe
It would be much easier for you and for me if you had mentioned the Operating System installed on your computer where you are going to install the printer. Anyway, select the suitable link for your operating system.
The Attention light is flashing red.
Solution The printer requires attention. Try the following:
* If the printer is connected to a computer, check the computer screen for
instructions.
* If you are printing a CD label on a CD/DVD, insert the CD/DVD holder in the
CD/DVD tray now.
* If you have a digital camera connected to the printer, check the camera screen
for instructions.
* If the printer is not connected to a computer, check for the following problems:
- Main cover open
- Out of paper
- Paper jam
- Print carriage jammed or stuck
- Print cartridge missing or inserted incorrectly
- Print cartridge tape not removed
- Incorrect print cartridge installed
- Packaging materials are not removed
* If you are unable to solve the problem by using the instructions above, turn off
the printer and unplug the printer power cord. Wait 10 seconds, and then plug
it in again. Turn on the printer.
