20 Most Recent
Samsung LN-T2342H 23 in. LCD HDTV Questions & Answers
The television simply shut down while being watched; the red light blinks when the remote control is used to turn it on; there is no picture and no sound.
Fault to the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
6/5/2015 12:35:49 PM •
Samsung...
Answered
on Jun 05, 2015
I have a Samsung T2342H
Sir I cant find your question in my activity. Try to use a dvd and let me what is your observation thank you.
8/7/2011 1:15:16 PM •
Samsung...
Answered
on Aug 07, 2011
How do i use it
To hook up your television to your PC, first you need to get the appropriate cable which is the cable you use in connecting your CPU to your monitor, then turn the back of the television and try to connect it to the port that is on the television.
Then turn on the television, and go to the AV mode, select from the different AV channels you have to be able to access the laptop.
That is how to hook up your television to your PC.
Take care
10/11/2010 12:19:01 AM •
Samsung...
Answered
on Oct 11, 2010
No power at all..help
The first place to look will be the power supply section, it must have at least the 5v standby power supply working, this 5v is always ON, it is used by the main controller board to turn on the rest of the TV.
Look for bad fuse, bad/burnt connection, bad capacitors.
http://en.wikipedia.org/wiki/Capacitor_plague
11/9/2009 2:45:59 AM •
Samsung...
Answered
on Nov 09, 2009
One side of my tv gets dim and out of focus it is a samsung. At times it works fine
back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
How do I troubleshoot my Samsung TV?
I have sound, but no picture.
Caps can fail with no outward signs. It takes a special meter to test them. Your set may have a back light inverter that powers the back lights. When it fails, the picture cant be seen, but you have sound, to check this look for a picture on the screen using a flashlight
My Samsung Tv modle LN46C600F3F has sound no picture, what could be wrong?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
Increase brightness in samsung tv
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
