20 Most Recent ViewSonic N3252w 32 in. LCD Television Questions & Answers
Most likely the power supply board needs to be replaced. Viewsonic is notorious for failure, it may not be worth trying to fix.
If you don't know what you're doing, DON'T OPEN THE MONITOR UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE MONITOR IS UNPLUGGED!
If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
ViewSonic N3252w... | Answered on Sep 21, 2016
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
ViewSonic N3252w... | Answered on Jan 15, 2015
Viewsonic 32" TV has an inline fuse. It is soldered to the power board. It is a small black cylinder. You can order a replacement fuse from aliexpress. Cost is about $1.40, but I had to purchase 10 for total cost of $14
Main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
ViewSonic N3252w... | Answered on Jul 07, 2014
check the source which gives you the signal for the hdmi! for an example, if you hook up you lap-top via hdmi with the tv, there is a setting on the lap-top and you choose: 1. transmit picture, 2. transmit sound, or do not transmit anything.
ViewSonic N3252w... | Answered on May 06, 2014
The power supply is faulty so you will need repair or replacement.
ViewSonic N3252w... | Answered on Nov 18, 2013
This model has a history of power supply problems. Depending on your level of expertise on electronic repair, you can repair the power supply or replace it. The most common repair is to replace the bulging power supply capacitors.
you go to a service centre near your area who repear it
ViewSonic N3252w... | Answered on Sep 17, 2013
The main board will have faulty component/s. Seek tech support.
There are keyboard locks that will lock the remote out on all functions there and remote lock outs that will do the same for the remote but both usually will not lock just one feature out especially if the power button works on the set but not with the remote.
ViewSonic N3252w... | Answered on Dec 18, 2012
Unplug the power, wait an hour, then plug it back while holding the power button down. This will reset back to factory settings and most likely will solve your problem.
ViewSonic N3252w... | Answered on Jul 02, 2012
You have to enter its service menu option, and make all suggested adjustmens there, after power board replacement. Download its service manual. Not user manual. It will have all service adjustments.
ViewSonic N3252w... | Answered on Jun 13, 2012
Download the repair book to this TV by net. It will have all details.
ViewSonic N3252w... | Answered on May 30, 2012
ViewSonic N3252w 32 in. LCD Television Logo
73 questions posted
Top ViewSonic Televison & Video Experts
lubomir73
Level 1 Expert
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • ViewSonic Televison & Video
Most Popular Question
viewsonic n3252w works about hour
  • Televison & Video
