20 Most Recent
Hitachi 42HDT79 42 in. Plasma Television Questions & Answers
I wanted to change the
If the tv was on when you unhooked it there is a cooling fan that didn't get to cool off the picture box and it has overheated and you will have to replace the box you can order it off of eBay it takes a few moments to replace it if you still have your owners manual it will tell you all about the lights on the front of your tv I've had to change mine out a few times hope this helps Merry Christmas
Why doesn't it turn on?
Try changing the fuse in the plug or making sure the power lead is pushed in the tv maybe a difrent socket. if these are ok then there is some thing wrong with the TVs its self could be a number of things better of taking it to a shop to be looked at !! Hope this helps !!..
Where do I attach audio output for headphones.
Excuse me brother, but if you have the owner's manual and the TV set in front of you, actually you are in a better position to find audio output. I don't have YOUR manual. Anyway, you can download one from the link I'll provide you, maybe it is more explicit then the one you have
Look at REAR panel and search for word "AUDIO OUT". If the plugs of your headphon won't fit AUDIO OUT connections take it a photo and go to a computer parts shop with your headphones ans purchase the appropiate converter
http://www.hitachiserviceusa.com:8080/55HDX99.pdf
Hitachi 42hdt79
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Tv wont turn on
check all electrolytic capacitors (cans) in the power supply (the board the mains connect to for flat tops (if the can has a rounded top it has failed and, must be replaced
Hitachi 42PD7200 Plasma TV gone dead
this problem is from smps power supply of your tv circuit, may be power capacitor may be short , power transister may be short pls check some spair of power supply
