20 Most Recent Samsung SC-D372 Camcorder Questions & Answers
3answers
When I turn it on
In the first place you must take a recording of the object and play. If the objects are irregular try and place an old recording done when there was no fault. If the recordings are seen well then the CCD can be a possible fault.
Now record and play the recording externally as you will be able to judge the result. If so the image sensor which is the CCD is defective. You might need to take an estimate from Samsung to confirm the cost and viability.
4/28/2011 10:34:28 AM • Samsung SC-D372... • Answered on Apr 28, 2011
DOESN'T CHARGE
It uses a Li-ion battery and once it goes below a set voltage it will not let the camera charge it, you will have to replace your battery.
2/8/2011 12:04:31 AM • Samsung SC-D372... • Answered on Feb 08, 2011
What does the DEW Symbo mean?
This means that there is condensation in your camera's mechanism. You need to thoroughly dry the camera out before attempting to use it.
12/25/2010 2:29:38 PM • Samsung SC-D372... • Answered on Dec 25, 2010
My camera is not turning
check to see if your cmra only takes certain kind of batteries some cmras do that
10/23/2010 3:17:43 PM • Samsung SC-D372... • Answered on Oct 23, 2010
USB not working- Samsung Digital SC-D372
take battery out and use mains power(might help)
5/19/2010 11:09:15 AM • Samsung SC-D372... • Answered on May 19, 2010
I want driver of windwos xp for samsung VP-D371i
should be here http://www.samsung.com/download/FileView.aspx?cttfileid=1126578&type=Camcorder&typecode=7&subtype=Mini-DV&subtypecode=701&model=VP-D371I&filetype=SW&language=
or direct link to zip file here for Win 98/ME/2K/XP http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=HQ&CttFileID=1126578&CDCttType=SW&ModelType=N&ModelName=VP-D371I&VPath=SW/200608/20060831090341703_Codec.zip
5/18/2010 2:21:02 PM • Samsung SC-D372... • Answered on May 18, 2010
Says its fully charged but is not
get a new battery
2/16/2010 11:23:30 PM • Samsung SC-D372... • Answered on Feb 16, 2010
2answers
It doesn't stay focused...gets blurry
Hello. The problem you are having is very common, actually universal with these Samsung camcorders at this price point. They simply do not stay in focus when you use the autofocus. The only good news is that you can go to manual focus which will provide you with no surprises.. The only fix for this autofocus problem is to upgrade. Regards, Joe
1/29/2010 8:42:51 AM • Samsung SC-D372... • Answered on Jan 29, 2010
Can my sc-d372 be used as webcam
if you can program it to the computer plus is there a way to hook up to pc
11/29/2009 9:00:39 PM • Samsung SC-D372... • Answered on Nov 29, 2009
The zoom button isn't working and therefore when
Follow the instructions below to check and test the focusing of the camcorder.
Manual Focus
✤ In the following situations, you may obtain better
results by adjusting the focus manually.
a. A picture containing several objects, some close to the
Camcorder, others further away.
b. A person enveloped in fog or surrounded by snow.
c. Very shiny or glossy surfaces like a car.
d. People or objects moving constantly or quickly
like an athlete or a crowd.
1. Set the [Power] switch to [CAMERA].
2. Set the [Mode] switch to [TAPE] or [CARD].
(SC-D375(H)/D975 only)
3. Press the [Q.MENU] button.
 Quick menu list will appear.
4. Press the up/down arrow button to select <Focus>, then
press the [OK] button.
5. Press the up/down arrow button to select <Manual>, then
6. To exit, press the [Q.MENU] button.
 The [MF] icon and the [MF/AF] status bar will be
displayed on the LCD screen.
7. Press the up/down arrow button to adjust the focus.
[ Note ]
Manual Focus is not available in the EASY.Q mode.
Make sure the lens is clean--use a soft cloth and don't press hard when wiping--use a circular motion starting from the center of the lens and working to the outside--that way, you wont grind dirt into the glass. If the lens is dirty enough, the camera will actually try to focus on the smudge or finger prints on the lens! Look into the lens and use the zoom button--do the interior lenses move forward and backward? The zoom button could be damaged(liquid or impact), or the lens could be jammed due to impact or liquid( I just fixed my sister-in-law's unit--had cola in it and sugar acts like super glue when dry.)(Lenses jam due to excess heat, too) NEVER leave a camcorder in a hot car. The grease used to enable the parts to move freely and smoothly can flow to sensitive areas and stick like glue.
If the focusing is indeed stuck, the unit must be repaired at a reputable facility. Don't send it in through a retail store unless under warranty.--Hope I was of help.---Rick
10/2/2009 4:49:51 AM • Samsung SC-D372... • Answered on Oct 02, 2009
How do i put video on the computer
There are two types of storage i camcoder. If it is hard disk Just connect your camcoder with USB to computer. In mycomputer you can see the disk of the camcoder as a new drive there.
If storage is DVD you have to burn it inorderd to copy it to computer.
If you are using a memory card you can remove it form the camcoder and using a card reader you can transfer video to computer.
Thanks
8/12/2009 5:59:43 PM • Samsung SC-D372... • Answered on Aug 12, 2009
Samsung sc-d372
something is outa alignment inside or something broke inside the transport. samsung builds stuff cheap but they have so many features . thats why people go for them. they dont last long.
7/31/2009 6:25:37 AM • Samsung SC-D372... • Answered on Jul 31, 2009
2answers
My samsung mini DV camera SC-D372 keeps flashing "Protection"
turn the camcorder off, take out the tape, look for the protection tab on the side of the tape and switch it to the other side.
protection is a feature of your tape to keep you from taping over important videos saved in your tape
7/31/2009 6:17:20 AM • Samsung SC-D372... • Answered on Jul 31, 2009
We have a Samsung Mini dv sc-d372 camcorder. It
if you can playback good old recorded tapes fine. you can record audio but no video ? this is the ccd. samsung is known for this in alot of there products ...did it get dropped or bumped really hard ?
7/31/2009 6:14:55 AM • Samsung SC-D372... • Answered on Jul 31, 2009
Cant record new video
check the memory card that you've inserted on your camcorder. tilt the protection tab of the memory card to unprotect it.
7/1/2009 7:21:38 PM • Samsung SC-D372... • Answered on Jul 01, 2009
Putting video from hi-8 camcorder to a dvd
FireWire IEEE-1394 PCMCIA 2 port CardBus Adapter - Increased speed ...Inserting the firewire IEEE1394 cardbus being inserted into the laptop cardbus port ... Make the connection between the FireWire CardBus and your DV camera, ...
www.usbgear.com/Firewire_PCMCIA_cardbus/
5/7/2009 2:16:02 AM • Samsung SC-D372... • Answered on May 07, 2009
How do i connect a Samsung SC D372 digital cam to
For your camcorder, your computer will need a simcard slot or you will have to order a cardbus with IEEE1394 connections.
FireWire IEEE-1394 PCMCIA 2 port CardBus Inserting the firewire IEEE1394 cardbus being inserted into the laptop cardbus port ... Make the connection between the FireWire CardBus and your DV camera, ...
5/7/2009 2:15:02 AM • Samsung SC-D372... • Answered on May 07, 2009
Samsung SC-D372 Camcorder Logo
45 questions posted
Top Samsung Video Cameras Experts
302lab
Level 1 Expert
NOEL
NOEL
 Grubhead
Grubhead
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
View Most Popular
SC Samsung
  • SC Samsung
Most Popular Question
zoom button isnt working therefore when
  • Video Cameras
