20 Most Recent
Lexmark C534dn Laser Printer Questions & Answers
I have a Lexmark C534dn
On laser printers, this can be caused by the charge roller or the print head. I would first look at cleaning thoroughly the charge roller (this is the roller that goes in to the Toner cartridge when you close the lid.
Use soapy water and let dry COMPLETELY before reinstalling. Or just replace it (better choice really)
This can also be caused by the print head and the fuser. so if the charge roller doesn't fix the problem, start looking there
Lexmark c534dn unsupported cartrige
This error message appears on the printer screen when the printer thinks
the wrong toner cartridge is installed. To clear it or identify a
service requirement, follow the steps below.
NOTE: If you succeed in resolving the problem at any stage during the procedure, you not need to perform the remaining steps.
- Open the top front cover of the printer. If the display DOES NOT read Close cover or Insert cartridge, the 32 error is not caused by the toner cartridge and printer service will be required to fix the problem.
- Make sure the correct toner cartridge is installed for this printer model.
- Check Lexmark for a list of compatible cartridges for your printer.
- If the wrong toner cartridge is installed, remove it and install the correct one.
- If
the correct toner cartridge is installed, it may not be seated
correctly. To ensure that this is not the cause of the error, do the
following:
- Turn off the printer.
- Reseat the toner cartridge.
- Close the lid.
- Power the printer back on and check the display.
- If
reseating the toner cartridge does not clear the error message and the
error started as soon as you installed this particular toner cartridge,
the cartridge may be broken. You can check this as follows:
- Power
off the printer and then reinstall the old cartridge. (You can also try
a different new cartridge to see if that clears the error.)
- If
the error does disappear, the problem may lie with this cartridge.
Please contact the point of purchase, especially if the cartridge is
brand new out of the box.
- If the error cannot be
cleared by putting in a new toner cartridge or one that is known to be
working, the printer may require service to fix the problem.
Every print I made still stock in the spooler
This is common. Just delete the first print job in the Que and the rest should start printing. The first one would be the one on top of the list. This happens when for some reason a print job fails. Then it holds up everything behind it.
Good Luck and Thank You for using Fixya.
WheatlandServices
Lexmark c534dn is printing on the left side of the
toner is going to empty, for instant solution take out toner cartridge and shake it for some time, then put it back to printer it will resolve your problem for a while but ultimate solution is replacement or re-fill.
How and where do I install memory cards?
www.
lexmark.com/publications/pdfs/2007/.../v7649663_en.pdf
LexmarkSetting up the printer as a copier only. ... Installing the optional XPS driver (Windows Vista users ...... Do not pinch the power cord between objects such as furniture .....Transfer photos and documents from a memory device to the computer over .... cSelect the print quality, the number of copies to print, the type of paper to be ...
www.
lexmark.com/publications/pdfs/2007/.../v7677571_en.pdf
LexmarkSetting up the printer as a copier only or fax only. .... Installing the optional XPS driver (Windows Vista users only). .... Information you will need to set up the printer on a wireless network................................................... ...... Inserting a memory card .Missing: c
How can I fix the missed OCR in Lexmark x3550 printer
Quite often the OCR portion is a third party software product and Lexmark cannot offer it as a download. Your best bet is to contact Lexmark customer support to see if they can help, but be advised they may want to charge for the disk.
