20 Most Recent
Ricoh Aficio SP C410DN Laser Printer Questions & Answers
Ricoh Aficio SP C420dn Printer. The printer at
sc491 is a high voltage output error. Combined with your jamming issue, it sounds like a possible electrical problem somewhere. A good first step is to turn the machine off and unplug it, then take off the covers and reset any connections or cables you can get to.
If the problem persists, you should have a service technician take a look at it because it might need a board replaced.
Error sc 366
TD sensor: Output minimum error [C]
Defective connector connection
Decreasing toner density
1. Replace the CYAN PCU.
Our Ricoh C4100N prints very slowly. We print
Yes but how many pages in a 35MB doc that takes take more than 20 min? How complex are the colour graphics, please?
That's meant to be capable of 25ppm according to cnet.com/products/ricoh-aficio-spc410dn/specs/
D'you know how much RAM it has? That page said it comes with 256MB but can take 512
Ricoh SP C410 DN jam from bypass
If you can take off the bypass unit, two screws and a harness, you may be able to check the shaft, bushings and rollers. Sometimes removing jammed paper cause parts to get out of normal position. The grinding noise for example, gears not meshing together correctly. If it worked before the jam, then that is where I would look.
How do fix error Color registration could not performed
Possible remedies for weak images.
-Loose connection between transfer roller and high voltage supply unit.
-Dust in the laser beam path
-Transfer belt not contacting PCU.
Check the transfer unit.
Defective PCU. Replace the PCU.
Defective transfer roller. Repair the transfer roller.
Defective fusing unit. Replace the fusing unit.
Defective engine board. Replace the engine board.
SC366 on SP410DN
This is a TD sensor output error.
Causes:
Defective connector
Replace the Cyan PCU.
Why is it indicating black toner is empty?
[Cause]
This may be caused by the Toner ID switch, that contacts the ID PWB on the Toner Bottle. The Toner ID switch has 4 wire contacts, if one of the contacts become crossed over this error may occur.
[Action]
Uncross and straighten the contacts.
If issue remains replace ID Chip Connector Harness [Part Number: G102 1120].
Error sc 430
Quenching lamp error--
lamp is defective
check lamp harness
other models-- transfer belt cleaning error
I have a ricoh c410dn
sc364 is a black toner density error. Typically, replacing the black PCU will get rid of the error message.
