20 Most Recent
HP LaserJet P2015n Printer Questions & Answers
I have black smudgy lines going down the left hand
1. Check the toner level, when it's low the quality of the prints becomes poor.
2. If toner level is good, clean out the printer inside. The best way is to buy an air compressed can, get the printer in an open space and blow any toner from the inside of the printer. Give it a good clean as there might be residual toner inside that make the poor quality.
Problems 64 bit win7 to shared 32 bit xp
insatall the 64 bit driver on the 64 bit pc then when asked if its local or networke choose Local set the bottom most drop down menu to standard tcp connection click next then in the address/location box type the IP address in manually
click next and finish installation job done
( your not sharing the printer to the 64 bit system - your installing the driver and allowing the Pc to share its connection with 32 bit systems)
Jammed error light litted
1) Turn off the printer.
2) Shutdown the PC to which the printer is connected.
3) Remove the USB/Serial cable through which the printer connects to the PC.
(4)Open the Front / Back Door of the printer and take a blower and clean any dirt inside. This will remove all the small paper particles that causes paper jam.
5) Now, reconnect the USB/Serial cable and switch ON the PC (only PC and not the printer).
6) Let the PC boot up and login to windows.7) Now, switch on the printer, PC should detect the printer automatically now.
It will only print if I unplug the printers power
Hello and Welcome to FixYa!Sir, This problem is usually occur sometimes, First of all Turn Off the Printer and change the USB Port of the printer cable, Connect it in other USB Port and then Turn On the Printer, Now try i hope it works but if problem still exist then surely it will be problem of driver, May be some files are getting miss, Try to re install the Driver of your printer, This problem will surely be solved.I hope you have clear picture in your mind, Don't hesitate to let me know if you have some confusionSir, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemedThank You for taking my serviceConcerned: Muhammad Uzair Team : FixYa
I have P2015n laser jet network printer. Since
1, Go to your services and restart Print spooler (start-run-services.msc) start stop it
2. Reinstall printer driver
3. Check your network or USB cable (depends how you have conected it)
Best regards
Lost the drivers to my printer
on this page:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=1845558&lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=1845551
select your operating system and go.
If this helps orsolves the issue, please rate it and give a testimonial for myresponse.
