20 Most Recent Westinghouse LTV-19w6 Television Questions & Answers
Did you try turning the tv on with the buttons on the tv?
TeeVeeMan2@gmail.com
Westinghouse... | Answered on Apr 19, 2016
The system control section circuit fault. Contact any service technician.
Make sure about the working of the remote control first. Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site in "Mosaic" or "Magazine" view. It will make surf easier.
If the remote control is found OK, the TV need through checkup.
Westinghouse... | Answered on Jul 25, 2014
An email from Westinghouse that fixed the problem for me.
Thank you for your inquiry.
We apologize for any inconvenience in waiting for our response, but below is what I can suggest to move forward.
It appears all you need to do is run a channel scan on the unit. Once you have run a channel scan, you will be able to scroll through the channels using the channel up and down buttons.
If you have any further questions, you may contact us through email, or by calling us toll-free at 1-866-287-5555, between 9am and 9pm Eastern Standard Time, Monday through Saturday. One of our technicians will
assist you.
Westinghouse... | Answered on Sep 12, 2013
Look to see correctly hooked and that in the menu the set is now not set to catv or cable but to air/antenna. If no antenna connected to set or if just indoor antenna you may not pickup on auto search--try to direct enter a known channel with the remote--if you get one you can in the set menu manually add to the memory the set has.
Westinghouse... | Answered on Nov 06, 2012
on the settings find TV/CABLE and switch to cable
Westinghouse... | Answered on Sep 27, 2012
What's the make and model of the universal remote? A common brand is one4all, http://www.oneforall.com/
If you find the model of the remote, you can find the book and the code for your TV.
Westinghouse... | Answered on Apr 25, 2011
You can try code 0463, although its a long shot.
Alternativley....this may work (a manual code search):
Turn on the device that you want to control. (TV)
Then press that device key on your remote once and release (the TV key as an example).
Press device key a second time and hold for at least 3 seconds, and release.
Hopefully, the device key is now flashing. Next, start pressing channel up repeatedly until the device you are trying to control turns off. When this happens, press the device key, this will lock in the code.
Note: When the device shuts off, you may have hit channel up before your brain realizes what happened (i.e. you will be one code off...so hit channel down and then the device key if you think you went to far)
Hope this helps!
Westinghouse... | Answered on Mar 28, 2011
Hello
You have to open it up to rectify this fault ofcourse. Due to hard hits, microswitches inside it may got damaged. Microswithces are the contact points when you operate the tV by the front panel. they can be located just behind the front panel switches, and inside your tV. To access it you have to open your TVs back cover. It is easy to locate these, and these will be small square shaped switches, directly soldered to a printed circuit board, and fitted on the front panel side of your tv. If anyome of these got strucked due to any hard hit, the whole front panel controls won't work; including remote sensor. You can also see the infrared remote sensor on that board. This is a three terminal part, usually look black in colour, there is a number laser printed printed on its side, and should be noted when you go to buy a new one. Replace the all microswitches at the same time. They are easly available, and cheap also. Desolder one amoung them and keep it in hand as a sample when you go to buy them, because there are so many types, differ each other in diamension and pin confuguration. Note for any printed circuit board breack or crack happend due the fall. If so, just bridge the cracks with a nice piece of copper wire, or two or three twisted copper strands from a wire. That is enough if there is a cracked. Normally this printed circuit board cannot be available. So repair it, if it has crack on it. Just examine very keenly for crak, as these may be sometimes microscopic.
If you wants anymore assistance, feel free to touch me through Fixya. OK.
Westinghouse... | Answered on Feb 25, 2011
Power supply has capacitors vented/swollen that needs replacing. Seen several posting asking how to fix. I replaced (2) 220uf 25v and (2) 1000uf 25v caps and the unit works fine now.
Westinghouse... | Answered on Dec 30, 2010
Westinghouse don't actually make TVs, they are just 'badged'. Westinghouse is part of the Electrolux group, so the obvious answer would be another Electrolux company that DO make TVs. The only one I can find is Philco, however I happen to know that some or all Philco units are made by Funai Corp. of China. The following are all TV brands made by Funai:
Funai
Magnavox
Symphonic
Sylvania
Superscan
Element
Philco
Durabrand
Trutech
Emerson
ESA
Try Philco codes first (if there are any) then work through the above list. It's likely that your TV is made by Funai and has the same components as one of the above brands. Please note that not all universal remotes will work with all TVs and universal remotes often don't work when the TV is newer than the remote.
Hope this helps!
Regards,
BElectric
Westinghouse... | Answered on Nov 18, 2010
If a generic brand remote doesn't list "Westinghouse," you're going to have to order a factory original. Went to Comcast site, scrolled down, and it said Westinghouse is........0463
Westinghouse... | Answered on Jul 04, 2010
Go to menu, use ch. keys and click audio, use vol. keys to go to sub-menu, when sub-menu appears, use ch. key and click down to the tv speakers under heading "speakers", turn them "off". On left side in the back are the audio plugins, the top two under the s-video plugin, red on top, white next down are the two audio speakers rca jacks. Plug your external speakers, like the ones that you'd buy for a computer, in those two. The manual does not say if you plug speakers in these jacks the tv's builtin speakers will be cut off, but this tv I got was being used for a computer monitor and the tv's speakers were turned off from the menu, so I guess plugging in external speakers does not turn off the tv's speakers and would interfer with the external speakers. I suppose you could try it both ways and see, leave the tv's speakers "on" and plug in externals and see if they are turned off automatically.
Westinghouse... | Answered on Jun 10, 2010
Westinghouse LTV-19w6 Television Logo
41 questions posted
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Westinghouse Televison & Video
Most Popular Question
screen stays white when tv turned off
  • Televison & Video
