20 Most Recent Sony Cyber-shot DSC-W200 Digital Camera Questions & Answers
2answers
How to display date
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
1/20/2020 10:46:31 AM • Sony Cyber-shot ... • Answered on Jan 20, 2020
2answers
Camera is flashing
The flash fuse on the main board or flash board is bad. Contact your local Sony service center for repair as this is possibly a short circuit problem but first try this......
I found a forum that talks about your error. Here is a quote from the forum:
TO SOLVE FLASH ERROR sony cybershot ERROR CODE E:91:01 , JUST GO TO SETUP MENU, SELECT THE TOOLBOX ICON 1 AND SELECT """"INITIALIZE"""" CLICK OK, MASTER RESET AND IT GOES BACK TO NORMAL.
please rate my help++++Thanks for using FIXYA
11/30/2018 9:39:57 AM • Sony Cyber-shot ... • Answered on Nov 30, 2018
Sony DSC-W200, 12.1 mega pixels stuck
I know this may sound a little simple but mine, though not same model, will do the same thing if the battery is not charged. Could also be a bad battery. Use this link to Sony for any other questions. https://www.sony.co.uk/electronics/support/compact-cameras-dscw-series/dsc-w200#faqs
10/15/2017 11:31:14 PM • Sony Cyber-shot ... • Answered on Oct 15, 2017
Can't get out of USB mode
You most likely need to change a setting called USB Connect under main settings 1. Page 67 of http://pdf.crse.com/manuals/3208400121.pdf Default is auto I suspect it is set to mass storage and is causing your hassle
3/4/2017 9:31:18 PM • Sony Cyber-shot ... • Answered on Mar 04, 2017
0answers
Flash
Be the first to answer 4/3/2014 7:17:02 AM • Sony Cyber-shot ... • Posted on Apr 03, 2014Be the first to answer
Can't get pitcher from camera
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
11/26/2012 5:48:18 PM • Sony Cyber-shot ... • Answered on Nov 26, 2012
SONY DSC-W200 HAS A BLANK SCREEN
If you have DISP/ DISPLAY button then press it 2 - 3 times and see the result. After that if the problem still same then take a snap & see it in PC. If the snap not taken by camera then its a CCD fault . If you able to see the photo in PC then its a LCD display problem & need servicing.
8/8/2012 12:26:43 PM • Sony Cyber-shot ... • Answered on Aug 08, 2012
My camera sony w200 is
I can Provide you LCD of Cybershot W200 if you are from Pakistan
11/16/2011 10:56:40 AM • Sony Cyber-shot ... • Answered on Nov 16, 2011
The camara got wet. We
I would put the camera into a bowl of rice (sounds crazy, but it works). The rice will **** the remaining water from the camera. If you are still having problems you will probably need to replace the camera.
8/5/2011 4:57:39 PM • Sony Cyber-shot ... • Answered on Aug 05, 2011
Where can i download instruction manual for this
Here it is:http://static.fixya.com/Manuals/S/Sony/Cybr_sht_DSC_431AC6D3CD1F09EA112E47E34ADB7BB3.pdf
7/28/2011 9:18:27 AM • Sony Cyber-shot ... • Answered on Jul 28, 2011
Lcd screen has only minimal
Your camera almost certainly has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Sony service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera, or at least are able to use the information to help decide whether to buy another camera. If you do decide that you have to throw your camera away then don't forget to remove the memory card as it can be used in other devices. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome.
7/15/2011 9:55:41 AM • Sony Cyber-shot ... • Answered on Jul 15, 2011
Red light by the battery
Hi bklynzrealis,
Seems that you battery needs charging, if you already did recharge the battery then the battery needs replacing if the red light blinks after charging.
I hope this help.
have a nice day,
mvincnetc
7/13/2011 12:01:26 AM • Sony Cyber-shot ... • Answered on Jul 13, 2011
My sony camera is from
Hi, http://www.docs.sony.com/release/DSCW200.pdf Is the instructional manual for that camera. You need to get into the menu then from there go to the bottom which would be settings, then go to the bottom of that screen which will be languages and then you should be able to set it to english.
5/12/2011 3:27:34 PM • Sony Cyber-shot ... • Answered on May 12, 2011
2answers
No memory space in internal memory-no more pictures can be taken!
there may be two problems. 1. Format your card before using it. 2. Switch your storage device to memory card and it will work. Hope it works..:))
5/2/2011 10:00:39 AM • Sony Cyber-shot ... • Answered on May 02, 2011
Sony Cyber-shot  DSC-W200 Digital Camera Logo
86 questions posted
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
sony camera from
  • Cameras
