20 Most Recent
Brother MFC-7820N Printer Questions & Answers
How do I connect a brother HL-5370DW printer with
This means your SSID, or the name of your wireless connection, the encryption method whether it be WEP or WPA or WPA2 and the Pre Shared Key, these won't be in your manual, but you would have set them up when you intially setup the wireless router.
11/14/2021 7:19:15 AM •
Brother...
Answered
on Nov 14, 2021
Brother MFC-7820N Printer--vertical lines
You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
Good Luck and thank you for using Fixya.
9/15/2021 9:21:20 PM •
Brother...
Answered
on Sep 15, 2021
Brother mfc- 665cw, receiving faxes
From the Brother web site.
Description of Problem 100000018247
When I launch PC-Fax Receive Program, I receive an error stating: The Fax Receive program must be started to receive PC faxes. What can I do?pc fax rx
Description of Solution 200000023257
You may receive this error if the pc fax application is closed and you have faxes stored in the memory of the machine. To resolve this issue,you will need to print the faxes already stored in the memory of the machine. To print the faxes, please follow these steps:
1. Press the MENU key.
2. Press the UP OR DOWN ARROW key to select Fax.
3. Press the OK key to confirm your choice.
4. Press the UP OR DOWN ARROW key to select Print Fax.
5. Press OK.
6. Press the BLACK START key.
- Your Brother machine will print the stored faxes.
7. Press the STOP/EXIT key to exit the menu.
8. Once the stored faxes have been printed, click WINDOWS/START, (ALL) PROGRAMS, BROTHER, XXX-XXXX (X = MODEL NUMBER), PC-FAX RECEIVING, XXX-XXXX or RECEIVE (depending on your operating system).
9. The Brother PC-fax receiving icon will now appear in your Windows Task Tray indicating that Brother PC-Fax Receiving is active.
5/9/2019 11:13:15 AM •
Brother...
Answered
on May 09, 2019
I would try a new print cartridge. There should be a cartridge cleaner built into the machine settings. Also the ink reservoir might need to be cleaned. I’m happy to help further over the phone at
https://www.6ya.com/expert/eric_7148ad2a373711a3
9/5/2018 12:07:23 AM •
Brother...
Answered
on Sep 05, 2018
hello! do you have the cd that came with the machine? if so you should be able to set up the lap top, also check to see if the printer has check matk beside it as the default printer. this would be in printer set up on the lap top good luck brother sr tech
9/4/2015 1:35:44 PM •
Brother...
Answered
on Sep 04, 2015
TENGO UN MENSAJE QUE DICE: CUBIERTA TRASERA
La solucion que me ha funcionado para una Brother DCP-7010 ha sido:
1.- Abrir la puerta trasera
2.- Bajar la cubierta trasera que esta justo delante del fusor. Para ello he pulsado hacia abajo las dos palancas de plastico azul en los laterales.
3.- En el interior de la cubierta, en la parte inferior derecha hay una barrita de plastico horizontal que aproximadamente en la mitad tiene un saliente (una barrita perpendicular de plastico). Dicho saliente debe estar metido en una ranura que tiene la cubierta trasera, en mi caso se habia salido.
4.- Una vez metido el palito en la ranura se cierran todas las puertas.
5.- Ponemos en marcha la impresora y vemos que ha desaparecido el error y ademas imprime.
Saludos.
Mau
9/18/2014 3:42:01 PM •
Brother...
Answered
on Sep 18, 2014
