20 Most Recent Samsung HP-T5064 50 in. Plasma HDTV Questions & Answers
The tv power supply board is dead.That the board,where the power a/c plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Samsung HP-T5064... | Answered on Mar 27, 2016
Make sure the power board are producing the correct voltages = or - 10 %. Look for domed electrolytic capacitors too. You can get repair kits and complete boards from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Samsung HP-T5064... | Answered on Feb 02, 2016
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Samsung HP-T5064... | Answered on Apr 12, 2015
You can also check for poor connections on ribbon cables etc.
Socketed Chips etc.
Modern TV's are more "Computer" than old fashioned TV. You could have memory problems, CPU or timing problems. Power supply problems.
Did the problem occur overnight. Like On/Off... or has it gradually gotten worse. All of these things can be clues. Does a slap on the back cause any glitches or changes to picture. If so then it could be an indicator of a physical problem like a poor connection.
Suggest getting a second tech's opinion before any replacement
Good Luck
Samsung HP-T5064... | Answered on Nov 27, 2014
SOUNDS LIKE THE POWER SUPPLY HAS GONE OUT, NEEDS TO BE REPLACED- FAIRLY COMMON PROBLEM.
Samsung HP-T5064... | Answered on Jun 02, 2014
check the wiring connections to the specific input you are using
is the device that broadcat the image active? reset this device
Samsung HP-T5064... | Answered on Apr 25, 2014
could be a sign of power supply failure. depending on where you are located there should some local repair shops that can repair that issue . however one of the first things i would try is changing your a/v cables to a higher quality one
Samsung HP-T5064... | Answered on Jan 02, 2014
Do you still have your old board,if you do put it back in and see if it does like the New Board.
In the mean time I need to do some checking on this model ,Samsung has some of these sets
that you have to replace 3 boards and On one model their is a 680uf 25v Capacitor that goes bad.
Have you looked all the boards over to make sure you have no swollen or vented on Top capacitors? Check your pico fuses also they will look like resistors but will be green or yellow.
1amp - 7amp pico fuses.The person who told you that the buffer boards where probably ok do they do TV Repair Daily? Or do Samsung warranty work? Ps it is possiable that you got a defective board just because they are new/rebuilt means nothing when it comes to repair, Ive had to ship a many of boards back due to being DOA dead on arrival? I paid $279.00 for a Deflection board that was No Good that really got me,Plus they losted my SSB board and that was another nightmare.
Samsung HP-T5064... | Answered on Jul 29, 2011
The capacitor is bulging or puffing up more than the other capacitors beside it?Yes,replace it with a new capacitor with the same micro ferit and 5 to 10 higher voltages for a better heat resistance later.This suspicious capacitor is on the power supply board.That the board,where the power a/c cord plug into it.Yes,90-95% that ur tv problems.
Samsung HP-T5064... | Answered on Mar 28, 2011
Samsung HP-T5064 50 in. Plasma HDTV Logo
57 questions posted
Jerry Greenberg
Jerry Greenberg
Ekse
View Most Popular
  • Samsung Televison & Video
Most Popular Question
samsung hp t5064 show grainy picture
  • Televison & Video
