20 Most Recent
Epson P4000 80 GB Digital Media Player Questions & Answers
Epson P-4000 accidentally formatted
I had the same problem. YOu may not need to restore the OS, but just get your hard disk moving again.
You need to remove the hard disk from the epson and attach it to your pc or mac, using a caddy.
The disk has two partitions. One is Epson-System, which contains all Epson software. If this is still ok, all you need to do is get the storage partition going again. The second partition is the one that contains your data. If it is corrupted, all you need to do is re-format it (DOS-FAT 32) and name it EPSON.
Put the hard disk back into the Epson, plug it in and switch it on. (If you switch it on using the battery it will still tell you to reset). It will now put the necessary file structure back and it works.
here's a how-to on removing the hard disk. I found this on another site:
To perform the repair yourself you are going to need to remove
8x case screws (very very easy)
4x internal screws holding the unit in place (very very easy)
1x internal screw hold the battery conductor in place (very very easy)
4x screws holding the phsyical hard drive in place (very very easy)
disconnecting speaker (easy)
unplug 2 data cables (easy but be careful, lifting up latches and they drop out)
sliding out the hard drive (its all pieced togeather like a 3 stack sandwitch)
Paul
Epson P4000
Hit the reset button. That's what it's for. I would say I'm 99.9% sure it's not going to erase the harddrive. That's one of the good things about a hard drive unit instead of flash memory.
How do i get my craig cmp1226e to advance to the
the little wheel at the top on the left side roll it to the right to advance to the next song. hold it to the right to advance quickly, and roll it to the left to go to the previous song. Push it straight down to get to the roo menu.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
