20 Most Recent Fuji FinePix Z5fd Digital Camera Questions & Answers
Camera says usb connected ALL THE TIME! it wont let me take photos
Screenshot or more details needed. This sounds like camera is faulty, but i dont want to believe it. Are we talking about web cam or like photo camera? If web cam, then just get new one from ebay, no point to have headache when they are so cheap on ebay. But if we are talking about photo camera then make sure you have right drivers installed, all usb settings are correct on cam. I mean, some devices are charging via usb and wont let you take photos unless you change usb setting to media transfer mode. Check those. But if photocam does a photoshot but image is blank then you might have a faulty photo cam
1/2/2018 6:28:08 AM • Fuji FinePix... • Answered on Jan 02, 2018
Can't upload pictures onto windows vista
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa. Organize edit and share your photos
11/20/2014 4:30:39 AM • Fuji FinePix... • Answered on Nov 20, 2014
My flash won't trigger on
I had same problem. Went to settings....reset. flash worked again. Don't ask me how it was a last resort and hey, it worked!
5/28/2013 12:08:16 AM • Fuji FinePix... • Answered on May 28, 2013
Frame full
I had the same problem with a fujifilm camera, the good news is that it's easy to fix. On the shooting menu (press menu when the camera is in shooting mode) there will usually be a set-up option, within that you should see "Frame No." or something similar- the two options for this are either "continuous" or "renew". If you are experiencing the Frame no. full error it means that you are currently set to continuous; TO SOLVE THIS PROBLEM SWITCH THIS SETTING TO RENEW.
Hope this helps!
4/16/2013 8:26:03 PM • Fuji FinePix... • Answered on Apr 16, 2013
Distorted viewfinder (washed out and
Examine with a magnifying glass for a crack. They can happen with pressure on the lcd.
9/19/2011 11:01:20 PM • Fuji FinePix... • Answered on Sep 19, 2011
I had my Fujifilm Pink
Try replacing the batteries. Unless the camera came with rechargeable batteries, they usually have to be replaced. Some pc's do not have the capabilities to recharge batters. Double check your paperwork that came with your camera.
8/15/2011 1:23:15 AM • Fuji FinePix... • Answered on Aug 15, 2011
How do you plug the
Look for arrows on your battery that correspond to symbols on the camera. If that doesn't work, peer in and take a look at where the contacts are inside the camera. Try to align the contacts on your battery to those when you insert it. Hope this works!
4/10/2011 7:28:54 AM • Fuji FinePix... • Answered on Apr 10, 2011
Camera will not connect with Mac
Consider NOT connecting your camera to your Mac.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
3/31/2011 5:28:30 PM • Fuji FinePix... • Answered on Mar 31, 2011
I have a fuji film
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
2/8/2011 1:49:11 AM • Fuji FinePix... • Answered on Feb 08, 2011
How do i turn off
asd
2/7/2011 2:42:28 AM • Fuji FinePix... • Answered on Feb 07, 2011
My fujifilm won't work on
Simple....get a card reader and download to a folder you create on your desktop. From there, you can import the pics to iPhoto. typrice_101.jpg
1/20/2011 8:22:31 PM • Fuji FinePix... • Answered on Jan 20, 2011
I have bought a F401
The newest review I could find on this camera was in 2007. I hope you received a manual with it. This camera uses an XD card an SD card will drop in the slot but not work. Okay when you first get the camera the day date and time need to be set. there is an internal battery that retains these settings. What you need to do is go into your menu and format your camera may call it initialize the memory card both the camera internal memory and the memory card in this case an XD card. It doesn't matter that it's a new card or camera the memory has to be formatted. each time you down load pictures to your computer hard drive the memory card will need to be formatted. After you have formatted your problem should go away, if not I'd be taking it back.
12/30/2010 9:13:07 PM • Fuji FinePix... • Answered on Dec 30, 2010
When i'm reviewing the pictures,
Does it should be the storage device of your FinePix Z5fd problem ,you'd better check it first.
11/22/2010 4:31:14 AM • Fuji FinePix... • Answered on Nov 22, 2010
My finepix z5 by fuji flash quit working how can i
I had the exact same problem; my camera wouldn't turn on when unplugged from the wall, and wasn't charging, and I thought that it was broken.
It turned out that I actually had the battery in the wrong way around (embarrassing for a technician really :| ) ; you have to flip the battery so the left is now the right side and vice versa. NOT top to bottom, just a flip on it's Y axis (if it were standing with the shortest face as a base).
7/27/2010 3:41:24 PM • Fuji FinePix... • Answered on Jul 27, 2010
5answers
Fuji Fine Pix Z5 battery won't charge
I looked up this question with the same problem and while the battery was placed in with the right side in, the three metal tabs weren't on the right side with the three metal chargers- so I had to spin it around the other way...i hope i'm explaining this right...now it's charging! I am so glad. This camera is excellent.
7/27/2010 11:38:22 AM • Fuji FinePix... • Answered on Jul 27, 2010
Keep getting the message `card not initialised` on
What happens when you try to format the card in the camera?
5/17/2010 5:56:56 PM • Fuji FinePix... • Answered on May 17, 2010
How do I transfer pictures from camera to pc
You can't.
The date is hidden in the exif data in each picture. But you can print images with date on them, thru the DPOF option in the camera playback menu. You need to have a Pictbridge compatible printer to do this.
4/14/2010 12:07:13 PM • Fuji FinePix... • Answered on Apr 14, 2010
The flash of my fuji does not work . it does flash
Try PhotoTech Repair Service, in NYC. They are factory authorized for most repairs, and are able to do warranty service in house. You can ship them your unit and, they are usually faster than the manufacturer, and cheaper! Plus if you join their facebook fan page they give you a 10% discount.
Here in the link to the facebook page, it has all the info you need.
http://www.facebook.com/pages/New-York-NY/Cell-Phone-Repair-NYC/312054784441
Hope it helps!
4/6/2010 12:59:58 AM • Fuji FinePix... • Answered on Apr 06, 2010
Nothing happens when I USB plug my Finepix z5 into
You could try taking the XD card out and plugging it into your Mac
3/25/2010 1:54:37 PM • Fuji FinePix... • Answered on Mar 25, 2010
My camera won't turn on
Your battery might have slipped out of the little slidy thingy, I once lost my XD card out of it and my camera would only take a few pictures.
3/25/2010 1:53:12 PM • Fuji FinePix... • Answered on Mar 25, 2010
Fuji FinePix Z5fd Digital Camera Logo
59 questions posted
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
View Most Popular
FinePix Fuji
  • FinePix Fuji
Most Popular Question
flash not work
  • Cameras
