20 Most Recent HP Compaq Presario V6000T Notebook Questions & Answers
I have a compaq laptop
Compaq Presario V6000T now retired at HP (zero support) ok its old. 12 long years old now!@!! first learn that old laptops do not have modern wifi chips. like other PCs have, a fact. the answer is Encryption modes. WEP , WPA or WPA2. in my home we have WPA2 ONLY AT THE ROUTER. for security reasons and no old laptop works with WPA2 then learn other homes running old gear, routers. have WEP on only and most new PC have that disabled, or gone now. WEP is net secure now at all so is gone. now lets answer you in more basic forum why not learn to setup the PC and your router the correct way. if your PC only does WEP/WPA (look does it?) then in the router, turn that on. if using wep turn it on, and know that you homes router can be hacked easy. if you have WPA, turn that on, and use only that if the PC can not use WPA2. use WPA for sure, at LEAST. turn off TKIP (use AES mode) too,. im reading your PC spec now. what wifi? it has 802.11b/g in most cases we must find out what wifi chip is there. and what OS you run, you never said windows what? then get the newest driver for that wifi chip. some are not available. finding the chip true name is not easy. I can but I have powerful scanners. the cure is , use the unsafe protocol or upgrade the driver, or buy wifi dongle USB (new) and use it. easy and cheap. use WPA2 only. if wise. next time post what OS you have nobody can match working drivers lacking that key fact is this stinking XP the DEAD OS? or vista? it too is now dead.
1/11/2018 3:09:26 PM • HP Compaq... • Answered on Jan 11, 2018
HP Presario V3000 internal wireless card not recognized
what OS? (means operating system)? we cant guess it... xp/vista/w7/w8/w10,? what? is it same OS as day 1 new? xp, does it have service pack 3 installed? if not, it wont work right. ever. if yes, XP did you install all drivers for this PC from HP.com oops they are gone... try to know that drivers for chips below the card must be good first. 3 years old to you? it not a 3 year old model at all. its a dead product with a square screen,.' its an old COMPAQ, 2006 , is my guess on DATE. looks like it has VISTA. Vista support ended this month and support is gone to on V3000 at HP. if you dig deep using HP, Google site searches some lingering elements remain. http://h10032.www1.hp.com/ctg/Manual/c01037981.pdf like that . the time to get DRIVER is before its 10 years old HP, dumps them at 10, or soon after that. find a newer lap top that has wide screen and upgraded it give this to the goodwill. (in fact they have newer ones cheap) it is a COMPAQ 2006 (HP bought them out LONG AGO) http://h10010.www1.hp.com/wwpc/images/ap/ds_consNB_presario_V3000_Intel_EN.pdf compaq is dead.
4/8/2017 6:22:54 PM • HP Compaq... • Answered on Apr 08, 2017
Done factory resent ,now cant start windows
it seems like the factory reset is not done properly..Please try to reset it again as right now you do not have any data.
4/3/2015 8:40:58 PM • HP Compaq... • Answered on Apr 03, 2015
I have 4 little screens on home page
For Four little screen on home page check 1.The Display setting by right clicking on the desktop,now go to the display properties and access all the settings very well 2. check maybe the VGA is installed properly on your system by going to your computer properties to the Hardware,from hardware to device manager you will now check mayebe the VGA is installed if it dies install it would have star it with yelow colour on that particular device
8/1/2014 12:03:54 PM • HP Compaq... • Answered on Aug 01, 2014
Accidently disabled display screen on my laptop
Normally you can switch between internal and external screen by holding the fn-key Down while hitting one of the function keys with a Screen symbol on (f7 or f8)
5/26/2014 5:08:30 PM • HP Compaq... • Answered on May 26, 2014
I con't connect with lcd projector, xp windows
The video output will automatically switch to the data projector first when you power up the data projector first and then boot up the laptop.
When you power up the laptop first you can toggle the Windows image between the LCD screen and the video port/data projector by pressing the Fn key plus the F4 key. Pressing these keys each time will switch the display from LCD screen to video port only, to both LCD screen and video port, and back to LCD screen only.
5/18/2014 4:40:42 PM • HP Compaq... • Answered on May 18, 2014
How do you change an artheros laptop wireless adapter
Is the adapter turned on? Is it getting signals from any other devices? If you need to replace it, it is a really quick and simple process. Flip the device over and unscrew the cover over it and it will usually have 1 or 2 screws holding the card down. It will be identified by having 2 wires running to it. Unsnap the 2 wires noting how they are plugged into the card now. Take the card out and look at it for a manufacture part number. Buy a replacement card by using that number. Installation is the reverse of this process. No drivers to contend with as it will be the same card. and it will be simple plug and play operation. it should take no more than 5 minutes to remove and reinstall an new card.
4/12/2014 11:38:15 PM • HP Compaq... • Answered on Apr 12, 2014
4/12/2014 11:37:14 PM • HP Compaq... • Answered on Apr 12, 2014
Microfonul nu merge
ther is problem with your driver or your mice or mice jeck
12/7/2013 7:27:04 AM • HP Compaq... • Answered on Dec 07, 2013
My laptop screen has been devided into four equal
right click on the desktop select screen resolution then click detect it should refresh the whole vga and fix it for u if that doesnt work reboot and while rebooting keep pressing f8 till u get a boot menu for windows then select start up with vga disabled
9/22/2013 11:32:39 AM • HP Compaq... • Answered on Sep 22, 2013
My friend has a HP Presario V6000, just randomly
Try connecting to an external screen if you get a picture the invertor needs replacing its at the bottom of the screen
8/19/2013 8:47:14 PM • HP Compaq... • Answered on Aug 19, 2013
My presario does not have an hdmi connection. what adapter do i need?
Try to conect through VGA or DVI
4/18/2013 12:23:56 PM • HP Compaq... • Answered on Apr 18, 2013
Compaq cq56 replaced LCD still black but work with external monitor
Please, just get it changed as early as possible
1/25/2013 8:33:33 AM • HP Compaq... • Answered on Jan 25, 2013
2answers
Compaq Presario v6000
please i wana compaqmodel no t2330 sound driver
1/3/2013 1:40:01 PM • HP Compaq... • Answered on Jan 03, 2013
Opening attachments
This isn't a problem with your laptop. A problem within yahoo website and i am also facing this issue. try to use gmail instead of yahoo. This problem is yahoo special. not to worry
12/2/2012 12:23:02 PM • HP Compaq... • Answered on Dec 02, 2012
Intel motherboard dq35j0
what is your question ?
11/15/2012 1:02:57 PM • HP Compaq... • Answered on Nov 15, 2012
2answers
My laptop hang so many times in a day pls give me
get an active anti virus or reinstall everything to facotry mode
rate this
9/27/2012 9:08:38 AM • HP Compaq... • Answered on Sep 27, 2012
2answers
Does my v6000 have a mic?
lol. no im sorry. I'm tell you that there is no built in mic unless there is a built in cam. if you have a built in cam try recording a video with sound. talk laugh play music. Then play it back. Also you can click Start then All Programs then click Accessories.
Now click Entertainment then Voice Recorder. Test to see if it plays you voice back. Sorry for the misunderstanding. Happy Holidays!
8/16/2012 6:05:49 PM • HP Compaq... • Answered on Aug 16, 2012
Letters y,u,h,j,n,m not functioning on keyboard
Sounds like you need the keyboard replaced. Just bring it to a computer shop and have them give you a quote on how much it will cost you. How much for the replacement keyboard, and how much for the labor. Replacing the keyboard will be a pretty easy job for them so get a quote for 30 minutes of labor. It won't even take them that long to fix it.
5/18/2012 1:02:39 AM • HP Compaq... • Answered on May 18, 2012
HP Compaq Presario V6000T Notebook Logo
Popular Tags
343 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Presario HP
  • Presario HP
Most Popular Question
done factory resent now start windows
  • Computers & Internet
