20 Most Recent
Brother DCP 130C All-In-One InkJet Printer Questions & Answers
How do i change the language?
I have Brother DCP-130C all in one Printer.
When I installed the
software I chose English as the language, but when i am scanning &
when i go into printing preferences it seems to be in German. I
un-installed & re-installed but still not in English.
Any ideas how I can change the language to english please?
Brother 130c print unable 50
Solution #1 is absolutely spot-on from adnanbhatti, copy the link into your browser to be able to see the photos of the printer and how to slide the print head:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000500/000065/faq000565_013.html?reg=us&c=us&lang=en&prod=dcp130c_all&Cat=11
When I slid the print head over as specified, I found a little crumpled paper fragment soaked with ink. Pulled it out.... I turned on the printer, it ran a cleaning cycle automatically, and started printing just fine!
My DCP 130c says machine
Hi
So the Init Unable 4F error means that the machine is unable to initialize, due to a mechanical problem or a foreign object / jam / paper jam inside the machine preventing it from starting up.
Open all the covers (and remove the paper tray and the back cover(s)) and inspect the printer for anything that does not belong to it, reseat or remove your print cartridges and clean any dust or similar out from the machine, also inspect the back cover of the machine, open it and make sure there are no paper jams and noting that doesn't belong there eg paper clip etc..
Once you have done all the above turn the printer on and if the problem remains, pull the power plug or switch it off at the wall (while still having the printer powered on) wait a few minutes and plug it back in and turn on, does the problem remain?
Clean unable 46
Hi, check to see if there is any foreign object jamming the print mechanism, check all drive belts. If this doesn't show nup any problems, I'm afraid that you have a failure that will require dis-assembly and repair by a company who deals in these printers.
Error 50 brother dcp 130 d
on my DCP 130C display appear an errore message "imp. stamp 50". This is an error message in italian language that indicate impossible to print, error 50.
Please, have you some suggestion to resolve this problem?
Thansk in advance
Init unable 51
Hi,The message means that there is something stuck inside the printer. Open it and look for staples, paper clips, torn pieces of paper, etc.Hope this helps. Please rate this response.Randy
Printer Error AF
The flat cable of the scanner wasn't connected properly. Try to straighten the end using your finger nails , then slot in the connector. Try again. Good luck
