20 Most Recent Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat Questions & Answers
Which IsoFix base do you have?
Maxi-Cosi... | Answered on Feb 09, 2020
I used a liquid washing tablet and did it on a cool wash in the washing machine. I found if I used washing powder it left white marks. Also, make sure you won't need it in a hurry as really you need to leave it to dry for about 48hrs.
Maxi-Cosi... | Answered on Nov 30, 2019
Good Afternoon
On either side of the EasyFix base you will see a small square opening with the yellow IsoFix point showing through it. Take a flat head screwdriver and slide into this hole facing toward the front of the car and gently push the screwdriver handle so it ends up facing the rear of the car - this should unlock the IsoFix mechanism. You'll need to do it on both sides if both sides are stuck.
If this doesn't work, or once you have done this, take the base back to your retailer with your proof of purchase if it is under 2 years old and they will be able to assist.
Maxi-Cosi... | Answered on Jan 08, 2015
If you're in the UK you can order direct from the customer care team
Maxi Cosi CabrioFix Spares
Maxi-Cosi... | Answered on Dec 15, 2014
Hi
Fabric is designed to be removed for washing, either handwash or handwash / delicate cycle on washing machine is fine, maximum 30 degrees, ensure you use additional rinse and spin to completely remove all detergent residue as leftovers will dry and leave white marks.
Maxi-Cosi... | Answered on Sep 14, 2014
Hi
Please contact us via the Facebook page with a PM so that we can send you instructions on removal of the base from the vehicle.
Hi
Page 7 CabrioFix User Manual
Hi
Maxi-Cosi do not produce adaptors for the carseats to be fitted on other manufacturers chassis. If there are adaptors to fit the Maxi-Cosi carseat to this model chassis they would be manufactured and sold by the manufacturer of the chassis, so you should contact them for assistance.
Maxi-Cosi... | Answered on Aug 17, 2014
Hi
To loosen the harness on the CabrioFix depress the button on the tensioner housing unit and pull both harness straps toward you together as instructed in the User Manual.
If this is not working it will need to come in for inspection and repair required. If you're in the UK and the carseat is under 24 months old please return to your retailer with proof of purchase for them to send to our engineers for inspection / repair under warranty terms and conditions. If you're in the UK and it is over 24 months old or you no longer have proof of purchase you can book in with the customer care team directly on 01284 413 141 Mon-Thur 08:30-17:30 / Fri 08:30-16:30 (Excluding Bank Holidays) Standard cost is 39.99GBP which does include courier collection and delivery. if you're not in the UK please visit www.maxi-cosi.com and select the country you're in, then choose the Contact Us tab on the right side of the screen for your enquiry to be sent through to the customer care team in your country who can assist.
Hi
We would advise you to contact Dorel Australia for assistance with available products which meet Australian standards. ce59fe75-733c-4d73-a2c1-b717a7b7c91e.jpg
Hi
What is your enquiry about the Maxi-Cosi CabrioFix please?
Hi Tobias
Due to the safety implications of the spare part item being incorrectly fitted we do have to strongly advise that the carseat is sent in for our engineers to provide inspection & repair. e51170d9-280f-4082-8d90-b13ea34998f1.jpg
Maxi-Cosi... | Answered on Apr 24, 2014
Try pressing down very hard on the seat while trying the release. If that does not work, call the manufacturer.
Note: if this does release, check the seat belt for damage before using again. Also check that the belt path used to install the base is/was correct.
-- Marc
Maxi-Cosi... | Answered on Jun 05, 2013
Hi
The harness of a carseat should never be removed or replaced by anyone other than a trained engineer due to the safety implications of it being incorrectly replaced.
The carseat fabric should be removed from this carseat and they can be washed - the harness itself should be cleaned in place in the carseat using a solution of stain remover and water and a small scrubbing brush or hard scourering pad to clean the harness. Excess water in the carseat should be dried immediately and thoroughly to prevent any parts rusting. Loose crumbs can be removed using a vacuum cleaner.
Alternatively the carseat can be sent in for the engineers to replace with a new one. Inspection and single repair (replacement of the harness) plus safety checks and courier collection and repair can be booked for 39.99GBP if you're in the UK by calling 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays)
Maxi-Cosi... | Answered on Mar 23, 2013
The Maxi Cosi Mico isn't a product available in the UK so we're unable to assist with your enquiry. Please contact Maxi Cosi USA by e-mailing to crelations@djgusa.com
Maxi-Cosi... | Answered on Mar 03, 2013
Maxi-Cosi CabrioFix (Black Reflection) Infant Car Seat Logo
213 questions posted
Top Maxi-Cosi Baby Gear Experts
Sunil Karickom
Level 1 Expert
ray gallant
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
View Most Popular
Maxi-Cosi Baby Gear
  • Maxi-Cosi Baby Gear
Most Popular Question
put footmuff maxi cosi carseat
  • Baby Gear
