20 Most Recent
ViewSonic N2751W 27 in. LCD Television Questions & Answers
REMOVE BACK COVER
There back cover is snap locked into place. Look around the outer edge carefully and you'll see small slots. Insert a small flathead screwdriver into these slots and work around the whole TV to release the snap locks.
Where is the power fuse located
fuse is located at the power supply section.to get to the power supply you need to remove the back cover of your monitor..after you remove the cover you can see the power supply..and the fuse is place on the pcboard and there are two fuses the primary fuse and the secondary fuse....be careful when replacing the blown fuse...do it only once once you replace the fuse and blown again there is a problem on your power supply...replace your power supply with a new one...
hope this could help you...goodluck!
your rate is important to this help tnx..
How do I replace the power supply board on my
hi! to replace the power supply you need to remove the back cover of your tv..once it is remove you can see the power supply...all its wirings are detatchable with connectors...and color coded be very carefull not to interchange them...
good luck! hope this could help you...
The tv had no power
There is no positive or negative polarity to a fuse. A fuse is just an in circuit protective device designed to blow when there is excessive current flow. A shorting transitor, coil or numerous other components in the power supply circuitry can cause this. Take power supply to television store, this will save you a fee from them having to come out, and have them diagnose the power supply, which they are good at. You might want to consider going online and ordering a new power supply.
No power, when plugged in, the led near the power
Hello, This is a very common problem with your set. There are several capacitors on the power supply board. usually they are rated at 1000uf@25v in the secondary. These caps overheat and leak.
This causes no 24v start up to the inverter board and the set will shut down in protect.
The power supply will need repair. This should be repaired by a service shop.
We can fix the power supply for you if you can disassemble and remove the supply.
Please visit http://www.albiontvandcomputer.com for the address to send your board.
Hope this helps, please be sure to rate my answer as it will help me too.
Thanks again,
Mike
