20 Most Recent
Argus QuickClix 5150 Digital Camera Questions & Answers
Hi, I lost my cd for my camera. I have a new comp
I just logged onto the Argus site....
- Go to it here: http://www.arguscamera.com
- Drop down the Support Tab
- Choose Manuals/Drivers
- Choose Drivers / Discontinued Cameras / DC5150 and push the "GO" button.
You will automatically have the Drivers for your camera downloaded in the form of an "exe" file.
You can also do this to get the camera's manual. They also have a "Contact Us" area, where you can either call or e-mail any questions you have to them.
I hope this works!
When I turn the camera on, the lens doesn't open
Hello :That's a common problem on these cameras. A moving coil actuator melts down inside and locks up an internal shutter closed permanently. You will need to open the camera and remove the shutter completely; no way to fix it.
Won't turn on, LED flashes red and green only.
Your
problem
may be due to weak/worn out batteries or corrosion on the battery
contacts inside the camera which can
prevent the full power of the batteries from flowing into the camera.
Try this free fix before you do anything else: remove the batteries and
wipe the camera contacts firmly with
a dry cloth (heavy corrosion may require cleaning with a wire brush,
steel wool, or sandpaper). Remove any residue that may have fallen
into the battery compartment during cleaning, then wipe both ends of
the batteries and place them back in the camera and give them a full
charge (assuming that you are using rechargeable batteries). This
cleaning clears
the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the
camera may have
a problem that requires professional repair.
If this response helps, please post a rating for me. A rating of "Very Helpful" would be appreciated . .
Picture down load
If your computer is Windows ME/2000/XP/Vista you will not need a disk or its software for this function.
Simply plug the camera into a USB port. make sure the camera is on ans set to upload-and Windows will put up the Camera/Scanner Wizard
Simply direct the images to a suitable folder.
Battery cover
yes there is take your card out and trash the camra
My father has never used
the power button is the small one on the top to the left
1- make sure that the batteries are "new"
2- make sure that they are on the correct position ( not the + and - locations on the cover from inside )
3- press the power button for 2-3 seconds
I hope this will help
Picture white
it could be from the erratic flash of light, against the sun, you can try focusing.
also turn the flash to auto mode.
dont forget to rate this pls
