20 Most Recent Westinghouse LCM-22w2 Television Questions & Answers
I have the same problem and have traced it down to a potential power supply issue.  I bought mine at Best Buy in '06 and was told today that they will test the power supply for free.  It may range from $50.00 to $100.00 depending on where you can get it.  This does not include labor for those not qualified to work with electronics.  Hope this helps you.
Westinghouse... | Answered on Dec 26, 2014
is there an indicator of power? LED light?
if there is a indicator that changes when input signal is insert, then the problem maybe on the LCD lamp sometimes this lamp are busted. if the indicator does not change maybe the problem is in the motherboard
Westinghouse... | Answered on Jul 20, 2011
Are you trying to hook it up for the purpose of watching cable tv? Because if so I am not sure that you will be able to hook it up directly without a box considering it probably doesn't have digital capabilities. You might try getting a converter box and try it then. Or it could be something as simple as changing the input on your screen. On this monitor in particular I believe it is one of the top buttons on the right back side of the monitor.
Westinghouse... | Answered on Jul 02, 2011
There is no tuner in the monitor, it only works as a TV with a tuner added. The remote would work with the tuner, not the monitor !
Westinghouse... | Answered on Jun 28, 2011
under the settings in westing house there is an option for minimum resolution deselect 480p and select 720p and higher.
Westinghouse... | Answered on Mar 14, 2011
Symptom shows it is power supply board problem that has back light inverter circuit as well, replacement of power supply board would solve tv problem.
Require power supply board is available in ShopJimmy.com for $103
Click above link for price info and online order.
If you are handy with electronics stuff repair then unplug tv from wall socket, take off its back cover by removing its all screws, remove screws of power board, unplug connectors and take out old power board from tv, put new power board, tight its screws, plug connectors and put back cover on tv.
Hope these info will help you.
Thanks.
Westinghouse... | Answered on Nov 18, 2010
When the lcd goes to a black screen after you turn it on within a couple of minutes or right at turn on the problem is the backlight in the lcd are not coming on. One way you can check is to use a flash light by shining it on the screen and look closely to see if you can see any images. Try touching the menu screen on remote to see if you can see image, if you can then the lcd screen is bad and would need to be replaced. The same would be if you can't see any image .this is costly repair but you can take to repair shop to get it checked out for a small fee.
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
Westinghouse... | Answered on Nov 01, 2010
Well kind of. Check your capacitors. If you search on the internet on how to replace the capacitors in a flat panel montior you will find tons of very detailed and informational videos and forums on how to do this. It is really quite simple and none the less cheap.
Westinghouse... | Answered on Sep 23, 2010
You should either check the cable you are using and possibly the ports on the monitor, if these both seem to be ok then it is probably your capacitors or a loose connection in the monitor. Also could be that your computer is not powering it up, so when you plug it back in make sure your computer power is off and then reboot otherwise it may not wake it up. More than likely the capacitors are going out, and it is still coming on shortly because they actually can hold a charge and they may not all be bad.
I had similar problems with my Monitor. Then eventually the monitor quit working completely. It is probably your capacitors. The reason you are still getting picture is because they are going out one by one if that makes any sense. If you search online for how to change the capacitors in a flat panel monitor there are a ton a very detailed videos and help files on how to do this. If you can solder it is a very easy fix and cheap none the less.
http://www.retrevo.com/support/Westinghouse-LCM-22W2-Monitors-manual/id/582bh530/t/2/
Please use this manual above and troubleshoot with the steps provided. Most likely your power supply may have failed, or the inverter, or backlight, you need to troubleshoot to be able to tell. But if there are No lights on at all. then first of course have you checked, the cable,power Socket, etc.
But if you cannot sort it out yourself, then, it is my professional opinion though that one should take their units to their manufacturers approved service center, contacting a head office, of your unit & getting an approved service center is just SO important, even worth the extra to ship it, you see, at those places, the Engineers, are trained on the equipment you have, they usually have parts on hand, and do the job quicker. Anyway do that and get a "Quote". This way, at least, you'll know weather to repair or replace.
Westinghouse... | Answered on Jun 17, 2010
dbutler1221, Possible Bad "switch-mode-power-supply"/"CCFL inverter circuit" that is or has developed an intermittant solder connection OR has problem with bad capacitors on same SMPS circuit board. You or a qualified electronics technician will need to open unit and visually inspect and test unit if WARRANTY SERVICE not an option. If DIY repair interests you, read some of the older (higher page num) responses to BLACK and or BLACKandBLANK LCD screen owners I have already done. Please come back to this posting you have done and rate my response after you have done the research and feel I have pointed you in the right direction. 12fixlouie Bye for now
Westinghouse... | Answered on Feb 06, 2010
The power supply on this model has a know issue. We just posted the repair guide on our web site at: www.ccl-la.com It gives a step by step repair guide for the Westinghouse LCM-22W3 monitor. If you don't want to do the repair yourself do do offer a repair service for $35 plus return shipping. If youhave any questions just let us know through our web site.
I hope this helps,If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Westinghouse... | Answered on Jan 03, 2010
I fixed it! It's the power supply board. You might have the "white screen of death" problem, and if not you may just need a new board. The board is yellow, it has markings on it that you can look up on a search engine for resellers, and I saw several going for $20-35 after searching google.
The Westinghouse LCM 22w2 has bad capacitors on the yellow power supply board. This is a common problem plaguing motherboards and LCD flatpanels that use capacitors from Taiwan. If you know how to solder, or know somebody that can, it's actually a pretty easy fix. Take out the yellow circuit board on the inside, write down the specifications for each of the capacitors (the cylindrical things) go to the electronics supply store and get the replacement capacitors. You can go over the voltage specification (not under), but keep the capacitance value matching. Replace one at a time. Go to www.badcaps.net for advice, tutorials and training on doing this. *You really should replace all the capacitors*, but the very large one next to the power plug I did leave on the board because I couldn't find a match. To my delight, the white screen of death went away and it was working as new!
I saved a ton of money fixing this, it's definitely worth learning how to solder to do this.
www.ctcco.com for professional hosting solutions
Westinghouse... | Answered on Jun 16, 2009
Westinghouse... | Answered on Apr 09, 2009
You need either a standard VGA cable or a DVI cable, depending on the type of video card you have.
http://www.ctcco.com for professional hosting solutions
Westinghouse LCM-22w2 Television Logo
Popular Tags
36 questions posted
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Westinghouse Televison & Video
Most Popular Question
westinghouse lcm22 w3 monitor comes when
  • Televison & Video
