20 Most Recent
Toshiba e-Studio 282 Printer Questions & Answers
"add paper" toshiba e-studio
Hi
CF60 indicates Recycle Toner Transport area lock. U need to take out the process unit, remove developer unit, remove drum, drum blade & recovery blade, disposed all waste toner, make sure the gear can turn properly. Then reassembly back everything.
Error CF60
Hello DDSFIX,
This is a fault relating to the toner recycling
system which is behind the black cover on the process unit-error code
suggests that it has locked.
The recycle toner transport area is locked thus CF60 sign on.
Please let me know if you have any further questions or concerns.
Thanks.
Hi, I have a Toshiba E-Studio 283 that is
Is it possible to print when connected directly to the printer? You can try it from another computer too to see if that works. That will help determine where the problem is. You can also try rebooting/resetting the printer and the computer and if that doesn't work try reinstalling the drivers.
Still, have issues please call me at 1800-204-4427. I can help you out via phone.
How to remove error e712
Clean RADF (document feeder) feed rolls with wet cloth, and open RADF cover and blow air so to clean and dust or small paper.
