20 Most Recent
Jazz JDC64 Digital Camera Questions & Answers
Jazz JDC6
try reformatting the card in the camera, I don't know if you deleted the pics from the camera with the computer, always delete pics from the camera with the camera,
I need to salvage older
Since this digital camera is an older model, it probably isn't compatible with 2GB memory cards. Older electronic devices including card readers, camcorders, MP3 players and even older laptops with built-in card readers won't be able to use higher-capacity cards. Try using a 1GB memory card in your camera and if it works, then 1GB is the maximum size of memory card you can use on that camera.
How to formatte camera JDC64
Hello Sir
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
Open up 'My Computer'. You should see it under the list of available drives.
Check its contents first to make sure that you have the right drive.
In 'My Computer', right-click on the drive and choose 'Format'.
5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Just starting to learn how to use and was able to
owww!
it sounds like you had a fulty camera to start with thats why it never stored your photos and hooking it up to the computer just pushed it over the edge with the belt it got off the usb port,,, i think its now seen better days,,, its realy not worth getting it fixed as the price would be close to the price of a new camera
sorry,, buy a new one its the best way out,
Card Protect error
Hi there
Take the write protect off by taking the card out
of the camera, face the card towards you, look for a small white tab on
the left hand side of the card, to unlock it push the tab down, it will
be at the side of the card like this
Also in the camera's menu you can format the card once the write protect lock is off.
Good luck and thanks for choosing FixYa!!
SD Card Needs Formatted
Thank you for using fixya. SD cards have a security lock on the side that you can toggle left to right or up and down.Check your card if it is on the secure mode or not, or you can just toggle the switch then check if it will start saving captures from your camera.
Lost disc
I want to buy the disc software if somebody have it.
Need Software
I need the disc software for a camera JDC64, let me know i somebody have it to buy it.
Jazz hdv185
Capture both video and stills with this handy camcorder. Its compact size makes it easy to take to any function without weighing down adventurers, while a USB connector allows them to port their recorded memories to a computer in a snap.
- Includes camera, USB cable, AV cable, MAGIX software: Video Easy SE, Photo Manager 9, instruction manual
- 2.6'' W x 4.9'' H x 1.9'' D
- Expandable memory: 8 GB SD/SDHC card
- Display size: 2.4'' LCD
- Megapixels: 14
- Zoom: 4x
- Input: USB / AV
- Requires four AAA batteries (not included)
- Imported
9/28/2020 9:11:26 AM •
Jazz Cameras
Answered
on Sep 28, 2020
