20 Most Recent Mintek DTV-373-D 37 in. LCD HDTV Questions & Answers
Need Dish remote control code
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls. Programming Notes • If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote. • Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality. This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
1/31/2016 4:14:53 PM • Mintek DTV-373-D... • Answered on Jan 31, 2016
I bought this tv used. The tv was not attached to the base she had it just resting in it. I would like to securely reattach it and can't figure out how. There are no screws either.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Disassemble & reassemble procedure to many popular brand TVs and other devices are given in detail with illustrations
8/22/2015 7:24:06 AM • Mintek DTV-373-D... • Answered on Aug 22, 2015
Picture on TV is out but sound still there what do I do
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/
8/10/2014 5:14:06 AM • Mintek DTV-373-D... • Answered on Aug 10, 2014
Nothing happens when plugged into a live outlet.
have you visualy check any open chip resistors on your power supply??if ok then thats the time to change the power supply board...
7/18/2014 5:51:07 PM • Mintek DTV-373-D... • Answered on Jul 18, 2014
My GPX 42" Has only one code, that don't work.
Almost every cable/satellite remote control thats used beingtoday, has an "Auto Programming Feature" on the remote.Look up your model cable box online for remote codes and I almost guarantee u will find the Auto Program instructions.For Directv u hold mute+select button for about 3 secondsthe flashes and so on . . . "LOOK IT UP"
11/15/2013 6:24:09 AM • Mintek DTV-373-D... • Answered on Nov 15, 2013
Tv with built in player plays perfect then shuts
check all capacitors on your power supply board, your voltages insufficient..
9/10/2013 11:44:25 AM • Mintek DTV-373-D... • Answered on Sep 10, 2013
Tv is stuck in dvd mode
The on l y way I've fixed this problem is by using a universal remote control. Using the input button, you should be able to switch it back to whatever mode you need. Hopefully your television is a major manufacturer.
9/10/2013 12:34:22 AM • Mintek DTV-373-D... • Answered on Sep 10, 2013
I need to replace the
the cost of replacing an lcd screen will be nearly as expensive as the cost of a new tv and it is also a time consuming and delicate task of removing all the pcb boards (without blowing them) to take the original screen out and then replace it all again.
3/18/2012 9:14:36 AM • Mintek DTV-373-D... • Answered on Mar 18, 2012
2answers
Codes
If you are using a remote supplied by your cable company with their box, check their website for possible codes for your set.
10/15/2011 1:46:19 AM • Mintek DTV-373-D... • Answered on Oct 15, 2011
4answers
TV w/ built in DVD
What a crock of **** this is guys! This FIX is surly a sad work around for the poor! Replace the mother board and solve your problem the correct way. No need to butcher up this TV. Better still, buy a name brand TV and a service contract which will save you money in the long run.
Dan Jackson - CET, which means Certified Electronics Technician
6/29/2011 1:32:34 PM • Mintek DTV-373-D... • Answered on Jun 29, 2011
3answers
Remote doesn't work
unplug from the wall socket and plug back in and try
1/18/2011 4:58:16 AM • Mintek DTV-373-D... • Answered on Jan 18, 2011
What year was this Tv made 0609090082003T2
Probably 2006 was the manufacturing date from the factory as the product listing started around then.
1/3/2011 6:46:45 PM • Mintek DTV-373-D... • Answered on Jan 03, 2011
Mintek DTV-373-D 37 in. LCD HDTV Logo
72 questions posted
Top Mintek Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mintek Televison & Video
Most Popular Question
nothing happens when plugged into live
  • Televison & Video
