20 Most Recent
Acer Aspire 5610 Notebook Questions & Answers
Hitachi hdd lock no password
There are very few HDD's that can be unlocked without the correct security being entered & unfortunately this is not one of them, it looks like you will need a new HDD.
Fn +f8 short cut key
Its for mute or unmute .. use fn key with up or down arrow key for controlling sound level..!!
A Disk read error occurred upon booting
This could be a sign of the hard drive having a problem.
I would recommend that you do a scan of the hard drive to check for errors.
You didn't mention which operating system you have, but you need to click on My Computer and then right-click on your hard drive. Go to Properties and then Tools.
Once there, select the option that tells you to check the disk for errors. Check the entire drive. Note that this will not run right away. You must restart your computer, as the utility needs exclusive access to the hard drive.
If this type of error reoccurs, it's time to back up your data, 'cause you probably have a hard drive that is dying.
ACER LAPTOP KEEPS FREEZING
Sounds like your system needs a anti-virus issue. Restart the system hitting the F8 key as it begins to start until it the system gives you option of how to start the system scroll down to "LAST GOOD CONFIGURATION THAT WORKED" click on that. The system should start as normal, once it has go to your anti-virus and run that - then go and do a system restore to a point before it began having the freezing problem. This usually comes from movie sites with pop ups do not click on pop up only go to sites you initiate.
Bluetooth installation
you need to disable your laptop.
The blue tooth connection is close to headphone jack, but you need to open the uppercase to connect your blue tooth.
Basicly you need the bluetooth and bluetooth cable.
Once you open the uppercase, you can see the internal microphone connection. the bluetooth connection is on the other side (motherboard).
Acer aspire 5536 forgotten the HDD user password
Assuming that after you enter the wrong three times it should generate a lockout error. At this time you can follow these steps to unlock the system:http://pcmediks.blogspot.com/2010/11/how-to-remove-hdd-user-password-in-acer.htmlBasically, once you unlock it, you should be able to boot into the BIOS and disable the HDD password. I'd say to do that first but you would need the password once you were in the BIOS to be able to disable it thus the recommendation to essentially set it to something you know first via the guide above.
Acer aspire cam not working
Working in what software? Is it in Device Manager, Imaging Devices? Is it enabled? What version of Windows are you using.
Restore aspire 5610
Hi Fentylfc,
Click "Start" menu.
Click "Programs."
Click "Acer Recovery Management."
Click the "Restore" button on the bottom of the dialog box that opens.
Click "Restore System to Factory Default."
Click "Yes" in the warning dialog box which asks if you wish to continue the recovery process.
Click "Start" to restore the computer to the default factory settings
If you are unable to access the Start menu, use the recovery CDs that came with the computer and
always make a back-up CD before restoring a computer to factory defaults.
Good Luck...
How can i make factory
Unlike
other laptops, Acer laptops integrate a computer management utility
called 'Acer eRecovery Management' to create backup of hard drive data,
create restore point, reinstall applications & drivers, and reset
Acer laptop to factory setting.Step 1: Before starting your Acer laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to
reset your Acer laptop. This process will erase all data from your hard
disk and reset your Acer laptop to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer laptop is reset to factory settings.Tips: You can also create a backup copy of your laptop data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.If you have any other issue with your Acer laptop/desktop/Notebook, feel free to get technical assistance at http://www.vtechsquad.com/acer-support/
