20 Most Recent Vivitek V37835 46 in. LCD Television Questions & Answers
Vivitek RP56HD22A loosing picture but sound is still there
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
4/23/2017 1:30:07 PM • Vivitek V37835... • Answered on Apr 23, 2017
2answers
How to reset lamp timer
Go to the menu and you'll find lamp timer section.
5/4/2013 10:14:01 PM • Vivitek V37835... • Answered on May 04, 2013
3answers
Vivitek 51
Fixed and very QUIET now!
It was the color wheel drive motor. $90 + s&h
Took about 20 min to replace. The top of the color wheel housing comes off with a couple philips head screws.
4/19/2013 7:26:09 PM • Vivitek V37835... • Answered on Apr 19, 2013
Where can i purchase the bulbs for a Vivitek LCD LT32PLI-A ?
tvrepairworld.com!
2/11/2012 8:06:13 PM • Vivitek V37835... • Answered on Feb 11, 2012
Vivitek tv hook up to playstation 3
depends on what kind of cable do you have. I recommend using a HDMI cable.
12/14/2011 2:21:19 PM • Vivitek V37835... • Answered on Dec 14, 2011
0answers
My vivitek 51 rptv will
you have to reset the lamp life timer .consult your manual go to the lamp menu and youll find the instruction on how to reset the timer..
4/22/2011 5:06:13 PM • Vivitek V37835... • Answered on Apr 22, 2011
4answers
Direct tv recorder and Vivitek V37835 46 in. LCD remote code for controller
IN THE GOOGLE SEARCH ENGINE TYPE VIVITEK V37835 MANUAL. ONCE YOU GET THE MANUAL LOOK IN THE SECTION OF THE MANUAL THAT SAYS SETUP CODES FOR SATTELITE RECEIVERS. FOLLOW THE INSTRUCTIONS FOR PROGRAMMING UR REMOTE. ALSO WANT TO LET YOU KNOW THAT I HAVE DISH SATTELITE AND I USE MY VIVITEK REMOTE NOT THE SATTELITE REMOTE FOR MY PROGRAMMING. MAYBE TRY THIS. IT WORKS FOR ME.
11/16/2010 1:55:02 AM • Vivitek V37835... • Answered on Nov 16, 2010
Need remote
Logitech Remotes work on about anything you just download whatever devices you have.
10/23/2010 5:51:08 PM • Vivitek V37835... • Answered on Oct 23, 2010
3answers
Screen is blank but the
In that case the image processor is dead. Since it's soldered to the mainboard and can't be removed, the entire mainboard will have to be replaced. Unfortunately your tv is a no-name one for which finding replacement parts will be difficult. Contact a local repairman, maybe he will know where to get one.
9/9/2010 6:03:30 AM • Vivitek V37835... • Answered on Sep 09, 2010
Nothing comes on lights flash yellow
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
6/30/2010 2:44:44 AM • Vivitek V37835... • Answered on Jun 30, 2010
Snaps on and off
Check inside, look at power supply and check the voltages.
Parts: www.shopjimmy.com
6/17/2010 4:42:30 AM • Vivitek V37835... • Answered on Jun 17, 2010
Vivitek lcd tv turns on and you can hear the sound
Check out the T-CON board connection and do some voltages checking.
6/17/2010 3:56:05 AM • Vivitek V37835... • Answered on Jun 17, 2010
When i power on the tv only the power button
Unplug the TV for Few Minutes, say 30 minutes and then Turn it ON. If the Problem still persists, it is a Hardware Fault.
Before we Proceed, Kindly answer few Questions :-
1. Make and Model of the TV?
2. How old the TV is?
3. Number of Blinks i.e 3 - 3 blinks then pause and then 3 blinks or is it continuous for few seconds or remain lit?
4. Do you have Soldering Experience or electronics experience?
Let me know,so that we could Proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
6/4/2010 3:52:28 AM • Vivitek V37835... • Answered on Jun 04, 2010
How much would it cost to replace a screen for a
I will be more than what new TV will cost, sell the TV for parts on EBAY and use the money toward new TV. LCD panel is the most expensive part of the TV.
WWW.SHOPJIMMY.COM
http://www.badcaps.net
5/30/2010 9:19:46 PM • Vivitek V37835... • Answered on May 30, 2010
I am trying to program Comcast Remote control for
Unfortunately there is no code for the Comcast remote that will control the Vivitek line of TV's. What you can try and do is a code scan. What the remote will do is try every code it is capable of producing and then if one of them works on your TV you can then lock it in.
Comcast has a number of different remotes but these instructions should work. If not then check your manual to see how to do the scan with your remote.
1) Turn on your TV.
2) Press the TV button once.
3) Then press and hold the Setup key until the TV key blinks twice.
4) Enter 9-9-1. The TV button will blink twice.
5) Aim the remote at your TV and then press the TV key and then the Power key.
6) Keep doing this until your TV turns off. Once it does that means you have found a key that works.
7) Press Setup button once to lock in the code. The TV button will blink twice.
This may take some time before it finds the correct code. There is also the possibility that the remote will not work with the Vivtek TV. If that is the case you may have to look at buying one of the truly universal remotes. These have far more codes for many more different types of TV;s. Logitech makes a number of them that you might want to look at.
There is also a website you might want to take a look at. It is:
http://www.remotecentral.com/index.html
This is a bulletin board for people that are having issues with their remotes. You can check on there to see if anyone has discovered the code for the Vivitek line.
Thank you for allowing us to assist you.
4/16/2010 10:04:34 PM • Vivitek V37835... • Answered on Apr 16, 2010
I have a vivitek 32 in. lcd hdtv.no picture
Tv have problem in power supply board.Check power board replaced the capacitors parts.Like puff up,burst up.Or replaced the whole power board,tries Shopjimmy.com,Ebay.com.
1/19/2010 12:12:38 AM • Vivitek V37835... • Answered on Jan 19, 2010
2answers
Trying to program a comcast remote (DVR 3 device)
iT WILL Take me awhile to do some reseach ,But I will get back to you on what codes that will work .I will first have to find out who makes vivitek,and which codes they maybe using.
1/10/2010 7:46:42 PM • Vivitek V37835... • Answered on Jan 10, 2010
2answers
COLOR WHEEL
Call Vance Baldwin.
They are on the net.
11/21/2009 10:53:32 PM • Vivitek V37835... • Answered on Nov 21, 2009
Vivitek V37835 46 in. LCD Television Logo
59 questions posted
Popular Products
Top Vivitek Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Vivitek Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vivitek Televison & Video
Most Popular Question
remote control stopped working no
  • Televison & Video
