20 Most Recent
Lenovo 3000 N100 Notebook PC Questions & Answers
Laptop shutting off every few minutes
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail. A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust. Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Lenovo 3000 N100 Laptop I need a schematic of the
Hi.Your not going to get a schematic manual for Lenovo laptops. As far as I know only Dell release service manuals for their products.The BIOS manufacturer of the laptop is Energy Star and is part of the system board itself. Regards.
How do i enable my
The wireless switch is at the front side of your Lenovo 3000 N100. (see pic.1). Press
Fn+F5 to confirm if your wireless switch is on. If required,
switch on the physical switch for your wireless connection.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
When i put on my
Welcome to Fixya
This could be a hardware problem. Lets try to eliminate the possbility of a software issue. Try to boot up the computer in safe mode first and let us see if it will give you the same problem. Turn on the computer then keep on tapping F8 key. Press safe mode when prompted.
Let me know of any development when you are done with the process.
Thank you for using Fixya! If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
N100 0768-41G keyboard problem " types@ @types"
Adam,
Please go to Control Panel->System->HW->Device Manager->Keyboard. Here, delete the keyboard, reboot and again reach here and from the Menu select Scan for New HW from Actions. It will reload the drivers for the keyboard.
I dont know how to install internet explore r
how to download internet explorer:
go to the link mentioned below:
http://www.microsoft.com/nz/windows/internet-explorer/default.aspx
and then click on download now and you are done.
I DONT HAVE A BLUETOOTH IN MY PC.
This particular model comes in two variants, with Bluetooth and without. If yours is equipped with Bluetooth, you need to search for the driver here:<br /><br />http://www-307.ibm.com/pc/support/site.wss/product.do?brandind=23&familyind=0&operatingsystemind=49979&template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&validate=true<br /><br />On the right side, about 1/3 from the top there is little window: "Enter a product number:", you need to find your 6digit product number and enter it there, this will provide you with links to the proper drivers.<br /><br />Unfortunately, you did not provided what operating system and what is your exact model number.<br /><br /><br />
Battery shuts off laptop and won;t charge up
Laptop batteries seem to not last too long. I see many that the owners keep the power supply on all the time, as the battery is dead. Unfortunately, the solution is a new battery. Do an internet search for "cheapest price on laptop bettery" with the make of your laptop, and be sure and look at several websites as some say they are the lowest, but others are a lot cheaper.
No audio device message. Also Code 43 when I
it conflicts with your sound device.
For that uninstall both driver from device manager.
Right click on my computer then click on property then hardware->device manager.
Then you can see all driver list uninstall sound and infrared driver then reinstall both then it will work fine.
If you haven't sound driver then download it from computer menufecturer web sites.
Let me know if you need further assistance.
Thanks for using FixYa.
I format my computer and install window after that
Reinstall the Driver for wired/wireless connection. Click on the links below to obtain the drivers that you need.
For Win XP Operating System Wired connection Click
here.
For wireless connection drivers click on the links appropriately.
Broadcom Wireless LAN Driver
For Windows Vista (32-bit) click
here.
For Windows XP click
here.
Intel Wireless LAN Driver
For Win XP Operating System click
here.
For any other drivers you need for your N100 Machine click
here for the list.
Should you have any other questions just please leave a comment.
Cheers~
