20 Most Recent Acer Aspire 5600 Series 5630-6951 Laptop Questions & Answers
you just have to format the laptop for you to solve the problem
Acer Aspire 5600... | Answered on Aug 14, 2017
may be this is an attack by some harmful viruses . i too experienced blue screens due to virus attack . downlaod avast proffesionl edition and install it (latest version availabel on katz.cd ) and scan computer at boot time ( avast only provides boot up scan ). otherwisw think of installing a fresh copy
Acer Aspire 5600... | Answered on Aug 07, 2017
u can format in progress install new windows
Acer Aspire 5600... | Answered on Apr 18, 2016
You must use OCR to do that, OCR means Optical Character Recognition, first you must scan the hard copy and save it as TIFF format and run through OCR reader, take note that convertion is not perfect, you still have to edit words that are not read correctly. You can download OCR reader on this link: http://finereader.abbyy.com/?gclid=CK6C96aflZ4CFRgbawodiDZ2oQ
Acer Aspire 5600... | Answered on Sep 16, 2015
you can reset the bios setting by removing the battery, you can also remove the jumper pin from the motherboard from pin1-2 to pin3-4 wait for 10sec then return to pin1-2
Acer Aspire 5600... | Answered on Mar 22, 2015
To find your computer's IP address
  1. Open Network Connections by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, type adapter, and then, under Network and Sharing Center, click View network connections.
  2. Select an active network connection, and then, in the toolbar, click View status of this connection. (You might need to click the chevron bf164617-11ac-4577-9d91-93f8f8f4aecc_40.jpg to find this command.)
  3. Click Details. Your computer's IP address appears in the Value column, next to IPv4 Address.
Acer Aspire 5600... | Answered on Mar 02, 2015
There is brightness only.
Acer Aspire 5600... | Answered on Feb 26, 2015
try rebooting or go into settings of device. when you first start your computer press F8 that will give you options.
Acer Aspire 5600... | Answered on Sep 29, 2014
There are a lot of Windows password revealers and crackers available, but I’ve found that Windows Password Recovery Tool is the most effective.:
it not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It works perfectly to reset any local user account to a blank password
You can use the ISO to burn a boot CD. Follow these instructions:
1. Download ISO file from http://www.windowspasswordsrecovery.com Windows Password Recovery Tool
2. Burn to a CD using a CD burning tool such as Nero or Roxio or MagicISO
3. Insert CD into drive and reboot.
4. You may have to select an option in the BIOS to get the computer to boot from the CD.
Booting up and clearing a password takes a minute or two works like a charm.
Acer Aspire 5600... | Answered on Aug 08, 2014
You can get the HDD master password for your acer laptop from http://www.unlockbiosrecovery.com/Unlock_Acer_HDD.phpFor $20 they will email your Acer HDD master password and they guarantee it t to work. I use them monthly in my work repairing laptops.
Acer Aspire 5600... | Answered on Jul 03, 2014
Restart your laptop.
After it shows acer logo..Press F8 multiple times... (preferably 3 to 5 times)
a screen will show you multiple options.. Select Safe mode (this will be first option and then hit enter... It will show you your Window name (windows 7 / windows xp) press enter again and it will boot your window in safe mode
regards,
Bilal
Acer Aspire 5600... | Answered on Jun 15, 2014
Well not enough information , ALT PLUS F10 at the start logo Will send you to recovery factory mode
work it out from there ,to what you want to restore
Acer Aspire 5600... | Answered on May 31, 2014
Hi
Which way have you tried to do the erecovery method
please add comment below explaining which way you did it
many thanks
Acer Aspire 5600... | Answered on May 27, 2014
check for an update of bios on acer.com it will fix your laptop problem....
Acer Aspire 5600... | Answered on May 24, 2014
Install CD rom softaware from acer website if it still does not work then it could be defective and you will have to replace it. sometimes, if you install incompatible software this happens too, in that case you will have to get your windows repaired.
Disconnect the power cord from the laptop and remove the main battery.
Open the laptop computer's screen and extend it as far back as it will go. Be careful not to stress the screen and cause any damage, but press it hard if needed.
  1. Press a flat head screwdriver under the front of the plastic bar lining the back of the laptop's keyboard. Pry the bar up slightly and hold it with one hand.
  2. Pry up the other side of the bar with the flat head screwdriver and fully pull out the bar. Keep its ribbon cord connected and set the bar on the laptop's screen.
  3. Remove the two Phillips screws securing the computer's keyboard. Slide the keyboard up and out to remove it. Again, do not remove its ribbon cord, and set the keyboard over the laptop's touch pad.
  4. Remove the four screws securing the cover plate over the motherboard and remove the plate as well.
  5. Locate the CMOS battery at the bottom-right corner of the motherboard.
Acer Aspire 5600... | Answered on Apr 27, 2014
Check your device manager for the imaging device ( webcam )
If not found, try booting into safe mode and give a look again in device manager.
If you have any usb devices connected disconnect them
If all of this do not work, you may have disconnected the webcam or could be bad.
Hope this helps
Acer Aspire 5600... | Answered on Apr 09, 2014
Acer Aspire 5600 Series 5630-6951 Laptop Logo
705 questions posted
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
computer start shut down continuously
  • Computers & Internet
