20 Most Recent Sanyo DP26746 26 in. LCD Television Questions & Answers
Your reported symptoms are odd in that most failures are related to the primary power supply but that takes down both audio and video.
The backlight is obviously working (white screen) but it is no longer receiving any video information and this points to a failure of the logic (or the output of the power supply that services logic) used to control pixels on the screen.  Some screens have the majority of the control ICs actually mounted on the LCD assembly and because of very close pin distances used on dense ICs, they are often not replaceable by hand since they were installed by robotics.
I would first suspect (and hope for) the logic voltage output of the power supply to be the culprit.
If any of you posters have had a repair done and received any kind of a detailed report (you should), would you be kind enough to post it back as a comment to this original message?
Sanyo DP26746 26... | Answered on Mar 01, 2018
Hi Raven
Is this a Question?
or are you just telling us that the volume won't go up?
Modern TV's are digital computers
So, the volume buttons don't actually turn up & down like in the past.
The internal computer gets up/down values from a register. Then it performs the change to the Amplifier.
SO... the point is
A technician needs to look at it unless you are technically inclined to check the power supply for say "Bulging Electrolytic Capacitors".
Good Luck
How to Replace an Electrolytic Capacitor
Switched mode power supply
Sanyo DP26746 26... | Answered on Mar 01, 2016
The power supply may be failing
Sanyo DP26746 26... | Answered on Feb 11, 2016
Contact the link below. They will guide you to have parts. If the set is obsolete, it will be very difficult to have parts.
http://us.sanyo.com/components/
Jerry G.
Sanyo DP26746 26... | Answered on Feb 28, 2015
hmmm..so you have power from supply board?
can you isolate the power supply board from control board, via connectors?
Sanyo DP26746 26... | Answered on Nov 16, 2014
There is no excuse to hold someone's gear hostage for a half-year. I hope for your sake that it was a 'factory authorized' service org.
If is was, contact Sanyo and raise Cain about it; this set seems to have way more problems than is common for the brand.
Sanyo Contact info
Sanyo DP26746 26... | Answered on May 22, 2014
Sanyo Manufacturing Corp. 1-870-633-5038
Sanyo DP26746 26... | Answered on Feb 05, 2014
The main system control memory IC is faulty. Replace it, and initialize the memory data to it. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Sanyo DP26746 26... | Answered on Oct 28, 2013
Hey Bobby, even though local channels for most places switched from analog to digital you still need an antenna. A digital antenna to be more precise. Advice: don't just get a digital antenna box, look for one that has an antenna on it. You can get some for $50 that will provide crystal clear picture. Speaking from experience. I hope this helps. Good luck.
- Joe
Sanyo DP26746 26... | Answered on Oct 23, 2013
THIS HAPPEND TO ME BEFORE MAKE SURE ALL OF YOUR LIKE SKY CABLES OR DVD SCART LEADS ARE FULLY CONNECTED TO THE TV ANF HAVE NO TEARS OR RIPS ON THE CABLE AND ALSO MAKE SURE THAT THE TV IS ON THE RIGHT AV CHANNEL BECAUSE YOU COULD HAVE CHANGED THE AV REALLY EASILY BY MISTAKE
Sanyo DP26746 26... | Answered on Sep 17, 2012
It sounds that the main digital board to your TV has damaged. But, before make it confirm, a through check should be done. Contact any experienced service technician for help. The work is skilled one, that a user cannot do it with ease.
Sanyo DP26746 26... | Answered on Jul 16, 2012
t-con
Sanyo DP26746 26... | Answered on Jul 11, 2012
No,Not repairable,because replacing the LCD screen panel itself,it will cost the same as a new tv.The LCD screen panel worth 90% of the tv,and it limited produced by the the tv corporations.Sorry the tv worth a whole tv anymore,only now worth a salvage tv electronic boards parts,that it.
Sanyo DP26746 26... | Answered on Sep 19, 2011
These sets are good with Power supply problems
Sanyo DP26746 26... | Answered on Apr 11, 2011
Sanyo DP26746 26 in. LCD Television Logo
90 questions posted
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sanyo Televison & Video
Most Popular Question
get tv pickup local digital
  • Televison & Video
