20 Most Recent
Mach Speed Trio Portable MP3 Player Questions & Answers
What is ebook for and what can u do on it
Ebooks are just computerized versions of there real counter parts you find in the bookstore.
If you want to read an ebook you must find them for download on the internet via a google search. Download them to your computer then hook your Ebook device to the PC and load them onto it.
Http://www.mylive-tech.com
I have a Binatone ebook
Click on the E-book that you want to download, and it would be downloaded on your computer.
Connect the Binatone ebook reader to your computer using its USB cord, then transfer the downloaded E-book to your Binatone ebook reader.
You can download more E-book files from the below link;
http://www.pdfgeni.org/us/binatone-ebook-pdf.htmlIf the above is not in correspondence with your question, please let me know.
Good luck.
My trio hype tablet wont turn on please help
more electric junk check the usb port / your probably toast and have to buy a new one . that stuff is way too sensitive to take abuse of modern man.. ohms testers at the shack or automotive section may help if ya get into circuit boards.
I have the Trio V2HD
Hi lilrusty2fw...
Go to Device Manager
To get to Device Manager you will:
Right click on My Computer>Properties>click the Hardware Tab>Device Manager.
After you are in Device Manager look for your MP3 player or Unit.
Here you should see no "Yellow" exclamation points.
If you do they they are telling you that you have a device conflict.
If you currnetly have your unit plugged in, you may notice the "unknown device" which would be your Player or Unit.
If you unit has an exclamation point by it, then you will need to click on it and delete it.
After you remove all devices with conflicts then click on refresh and search again for your MP3 player/Device.
The computer should install your device this time and solve your problem with connection of the MP3 player/Device.
Please take time to rate me thumbs up.
How long is my Trio supposed to play? I'm only
As per the company specifications it should provide up to 8 Hours of Continuous Playback. I'd suggest that you set the light out time at 10 seconds keep power saving mode and reduce the brightness. Also dont play at full volume.
This will help you to increase the playback time. Though not up to 8 hours. Make sure not to overcharge the battery.
Also the video playback time is 3-4 hours. As you have not specified whether you are reffering to audio or video playback time, so I am assuming its audio playback time. If its video or mixed then your player is ok..
Hope this helps..
Hey my trio is froz how do u fix it
There is a reset switch on all MP3 players located somewhere on the chassis, you are looking for a hole that a safety pin can fit into, once found press and hold for 60 seconds to clear the microprocessor ic, if this fails to work it may be time to replace the player.
Player turns on but will not respond
maybe the memory is full,,try to free up some memory by deleting unused or unwanted files..
if you can't do it direct to your mp3,then plug it in to a computer then do the mentioned above..if
problem still same,then insert other memory card that works,
goodluck and if this you think somewhat helpful,then rate...thanks
How can i add music
Sync with the media player and drag and drop songs from left to right and then click sync after list hasbeen made of course connect your player
Fix my headphone jack to my mp3 player
Did you mean how to fix the jack/ if so you will need to solder the new jack with stereo leads of the headphones or have a connecting cord with dual jack or RCA to be used into another input.
Is that the question ?
