20 Most Recent Canon PIXMA iP6700D InkJet Photo Printer Questions & Answers
2answers
Canon ip6700d error number 1415
I think I have come up with a solution!
When the error happens:
Open the cover and re-seat the cartridge.
Tilt the whole printer forward about 30 degrees or more
Close the cover.
This has worked for me multiple times now. I think there is a small sensor behind the contact chip that detects ink levels and when my printer is flat the level of ink is lower than the sensor, when I tilt the printer the error vanishes because the ink covers the sensor. Though I am not sure why the software in the printer determines that there are duplicate cartridges instead of just a low ink warning.
If you still can't get it try taking a standard pencil eraser and gently rub it over the contacts to clean off any oxidation, also do this to the prongs that contact the chip that are inside the cartridge carrier, They bend easily so do it very lightly.
10/18/2022 10:29:42 AM • Canon PIXMA ... • Answered on Oct 18, 2022
2answers
Error U130 Cannon ink tank
it is possible that the ink chip is damage. try to buy another. or you can buy original ink to make sure the printer is ok.
11/29/2021 6:41:06 PM • Canon PIXMA ... • Answered on Nov 29, 2021
Error code 5200
- unplug the power n usb cord
- keep the headprint inside the craddle
- try to move the headprint into full right-corner(headprint
cleaningside)by moving-left the craddle belt until u heard
some "snapp" sound
- plug the powercord again
- if u heard "cleaning progress" then u r printer going to respond
- try to print 'printer test page' or 'nozzle check'
- if it succeed, try to print some 5-10 pages continuous
the dreaded 'Error 5200'. According to PrintX, the error is caused by printer head overheating and I think thats correct because whenever I touch the "Do not touch/ hands off" part of the print head, I feel some SCALDING heat.
TIPS. 1. Plug out your printer when not in use. Never let it undergo standby mode. Plug it in ONLY when it is needed. The reason behind this is that your printer only needs VERY little amount of electricity (around 5-24 V at 0.2-0.55 A, stepped down by its built-in transformer) and after a length of time, excessive heat accumulates not only in the heat board but also in the sensitive print head. Unlike how our computers heat up, the heat in the print head is SCALDING!. This is based from experience. Try touching your printer's too.
IP1500 error5200
1. Set "ink counter reset" (If you chage cartridge new one or refill).
2. Set "low ink warning setting" as default.
3. Unplug power and USB cable.
4. Waiting 10 min.
5. pluging in power and USB cable.
Please make 1 step and check result.
Good luck
http://www.cyber-ink.com/member-canon.html
Handy link above.
http://www.nodevice.com/manual/newmans/1164257352iP6600Dsmpdf/get13866.html
Service manual link above get this it is invaluable for repair.
http://www.nodevice.com/manual/Canon/page15.html
Link for SM, in case link above is dead.
5/20/2019 11:35:59 AM • Canon PIXMA ... • Answered on May 20, 2019
My Canon ip6700D will not
Some printers will not work when ink levels are low. PIA.
6/17/2017 2:27:36 PM • Canon PIXMA ... • Answered on Jun 17, 2017
0answers
0answers
Power failure on Canon pixma ip6700d. There is
check USB connection if it has one.
1/21/2016 9:43:06 AM • Canon PIXMA ... • Answered on Jan 21, 2016
Working on a canon Pixma Ip6700d printer. When I plug in the printer the alarm light stays on? The absorber kit was just replace the other day.
Hey Brian, I know it's been awhile, but were you ever able to get this printer working? I have one that I bought off of CL and am experiencing the same issue. This particular printer definitely hasn't been used enough to require new parts, and of course it's not actually giving me an error message anyway, only the yellow light comes on. I'd love to find a fix if it's possible.
7/9/2014 5:27:01 PM • Canon PIXMA ... • Answered on Jul 09, 2014
How do I clean ink off of feed rollers?
I use rubbing alcohol.
6/6/2014 9:59:32 AM • Canon PIXMA ... • Answered on Jun 06, 2014
0answers
2answers
There is a massage displaying error code 5B00
error code 5b00 canon ip 4950
4/15/2014 2:27:41 PM • Canon PIXMA ... • Answered on Apr 15, 2014
0answers
I need help reattaching the spring on L-shaped ink thing
please help me!! canon mx416 absorber full (5b00) how to reset this canon perinter?
9/21/2013 9:15:45 AM • Canon PIXMA ... • Answered on Sep 21, 2013
How to reset canon pixma mx416 printer?
please help me!! canon mx416 absorber full (5b00), how to reset?
9/21/2013 9:14:14 AM • Canon PIXMA ... • Answered on Sep 21, 2013
2answers
I am not out of toner but nothing is printing out
If you let the printer sit for a few weeks, months, or years without printing before you tried to print then your print head is probably dried up and clogged. If this is the case you can buy a new print head from Precision Roller (a reputable on-line company) for $80.
5/23/2013 7:07:54 AM • Canon PIXMA ... • Answered on May 23, 2013
4answers
Ink Tank not recognized
Here's info on the reset:When your printer detects a problem with the cartridge you are attempting to use, a flag is set inside the device. This flag may not reset until you perform a hard reset on the device. 1. Verify that the printer is turned on.2. Open printer's lid/top cover and remove all of the cartridges from their carriers. Close the lid/top cover.3. Unplug the power cord from the printer.4. Wait for 10 minutes.5. Plug the power cord back into the printer.6. Open the lid/top cover and reinsert both cartridges back in to their carriers.7. Turn the printer on.8. Print a test page.
12/10/2012 11:37:24 PM • Canon PIXMA ... • Answered on Dec 10, 2012
Canon PIXMA  iP6700D InkJet Photo Printer Logo
164 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
  • Office Equipment & Supplies
