20 Most Recent
Canon PIXMA iP1800 Printer Questions & Answers
I lost the installation CD and needs to install
You can download the installation driver and software from manufacturer's site by clicking this
link
- On the page which opens, select the operating system of your computer (Windows Xp/ Vista..) from the drop-down menu as shown in the attached image and download the required drivers and software.
- The list of available drivers will load only after selecting the operating system of the computer.
Hope this solves your problem. Thanks for using FixYa.
How to remove ink in th full ink absorber?
waste ink absorber error message can sometimes be solved by resetting the printer itself. i havent yet tried in ip1880 but in ip1200, th e resetting method is this: (it might also work on other models)
1. unplug the power cord and the data cable(printer to pc)
2. while press-holding the (printer) power button plug the power cable (do not release printer power button until step 3)
3. press 'resumet' ( the button below the power button of the printer) button twice...
4. release the power button
5. connect the usb cable of the printer to the pc...
- a new canon printer shall be found in the list of printers. use it as default printer
Service error 5100 and 6000
Canon tells you to unplug the machine without the head in for 30 minutes.
Replug into outlet and cross fingers./
If that does not work you may need a new printer
Canon ip1800 ... ink absorber
1. remove cartridges
2. unplug AC power
3. hold power button and plug AC power (keep holding power button.
4. press resume 4 times
The waste ink counter should be reset by now
i hope this helpfull
please rate very helpfull if you think this helpfull
thanks for using fixya
Ink not properly installed
are you using genuine inks? if so then I suspect a faulty printer, if your using refilled inks then the counter on the cartridges has probably kicked in, you would need to press & hold the button with a circle and triangle on it in for around 10 seconds, this overrides the software designed to stop you using your refilled inks.
