20 Most Recent
Xerox Phaser 8500/DN Printer Questions & Answers
Stuck 8560 waste tray
You will probably have to remove the left side cover and clean some spilled ink from around the waste tray.
That normally is what causes that.
There is a tray lock on the machine, but I personally have not seen that be an issue.
If there is a lot of ink in the machine. make sure after you clean it out, that you level the machine front to back and side to side. You do that by placing a level on the glass and level it up by that.
The lamination paper is stuck.
you need to use the carrier (cardboard cover) that the lamination paper comes with.. if you dont use the carrier your plastic will stick to the hot rollers... you will need to take it apart and clean out the plastic.. easy to dow hen it is cold peels off easily... pain in the neck getting it back together as the wires in the front interfere with the front screw post...
05.004.44 :91032
Service manual says:
5,004.44: Y-Axis fault_general fail problem with Drum motion sub-system.
I have a Phaser 8500.
are you using the correct driver? If you are printing from an Apple Mac you need to load the postscript driver other wise install the pcl6 driver
Xerox Phaser 8550dt printer
That is a known problem with the 8500 phaser family.
Contact Xerox at 1-800-835-6100, They WILL replace it for free. It is a known problem.
I really believe that display is failing. very common problem.
Just tell them the display is blank when you call. But they are faulty. Very faulty.
Xerox 8560 error code 07,007.40
That error signifies a problem with the printhead tilt, you need to replace the Process motor camshaft pivot kit, part number 8560-Z2.
http://www.iteminconline.com/8560-z2_8560-z2-xerox-8560-process-motor-camshaft-kit.htm
Error number 09,038,46:31624
That error signifies that the flag is stuck in the black slot of the ink loader, replace the inkloader, part number 133K27710
http://www.iteminconline.com/itemdesc.asp?ic=133K27711&eq=&Tp=
Xerox phaser 8500dn error message
This is an electronics problem. The voltages are 20% off from expected values.
Try running the machine plugged directly into the wall, with no other equipment on the same circuit. This is how you should run this printer, whether this solves the problem or not.
Of course you may have bad parts, such as the Wave Amp Board 960K21180 or the Electronics Module 137E14020
Whit
Item, Inc
Phaser 8500 error code 19,003.48:64663
19.003:48 is the error code 64663is the number of pages the unit has printed. the error indicates a power difference of +- 20% when trying to drive the printhead. The issue is the Electronics Module (System logic and power) or the Wave Amplifier (Printhead Controller). Both of the parts are fairly easy to replace. If it is the wave amp it is a somewhat affordable part.if it is the EM you should replace the printer. It isn't worth the fix.
Xerox phaser 8500 error 19003.48:33702
19.003:48 is the error code 33702 is the number of pages the unit has printed. the error indicates a power difference of +- 20% when trying to drive the printhead. The issue is the Electronics Module (System logic and power) or the Wave Amplifier (Printhead Controller). Both of the parts are fairly easy to replace. If it is the wave amp it is a somewhat affordable part.if it is the EM you should replace the printer. It isn't worth the fix.
