20 Most Recent HP Compaq tc4400 Notebook Questions & Answers
2answers
Tablet buttons behave as if they're constantly being pressed
Guess is...your keyboard needs to be replaced. Give this a try and see what happens next.
10/8/2017 12:23:25 PM • HP Compaq tc4400... • Answered on Oct 08, 2017
Sorry for my ignorance, first
Backups do NOT Erase files ever, well if not done backwards?NO OS stated, how can any one help lacking that.TC4400 hard ware. ONLY !no boot, the HDD will not boot , unstated windows, or is it linux?>windows what.?sounds XP like to me... the book on your PC tells you to use restore to fix, bad loaders.startup repair its called, on mine its F11.on Vista back is F10. this key activates here is what came new.HP Compaq tc4400 Tablet PCit came with Windows 2000,XP or Vitstaits so old it has a SQUARE scree, 4:5 ratio.the carbon date is as old as, 2006It is still supported by HP due to it was made for all those years.and the 10 year clock is not timed out yet on support.sthe books are still on line and the drivers too.see these books>https://support.hp.com/us-en/product/hp-compaq-tc4400-tablet-pc/1847962/manualsdoes BIOS work, press F10 at power on, see BIOS screensthis is first,then the BIOS then boots the HDD, C: boots.to repair a good HDD, startup one runs this.F11 is your hot key, for HP recovery /restore.page 188 here is the page (PDFPAGE) to read.http://h10032.www1.hp.com/ctg/Manual/c00692629the books says, on that page follow the onscreen instructionsit says that to cop out, as there are 3 OS used, here.each uses different screensI too cop out, not doing all 3 now for you.next time say what OS is there.on the bottom of said PCis a COA sticker on said sticker is the MS licenseclearly stating what OS is there. (was there day 1)but if someone upgraded this PC, then the sticker is a lie.oops but you killed the HDD totally dead of all partitions did you not? Sanitized, word, used.no name of disk used, my guess is MIL spec erase.
6/9/2017 1:46:04 PM • HP Compaq tc4400... • Answered on Jun 09, 2017
How to do if error code 0x80070590 came
It happens because the system can not find some of the files during installation. What boot device are you using CD or flash drive. Try to install from a boot-able flash drive. This may solve your problem. Please inform if you face the same problem again.
3/5/2015 8:44:53 AM • HP Compaq tc4400... • Answered on Mar 05, 2015
Why does my pointer sporadically move around and click on it's own sometimes?
Try updating your touchpad driver from device manager.
8/19/2012 5:37:40 AM • HP Compaq tc4400... • Answered on Aug 19, 2012
Hi i made a partition
if you create a new partition on your hard drive with anything but partition magic or something similar, the process of creating the partition will wipe all data from the entire hard drive to resize the partition. you will probably need to re-install Windows fresh unless the utility you used just happens to have an undo (not very likely) playing with partition sizes of used drives is not advisable.
3/21/2011 10:08:51 PM • HP Compaq tc4400... • Answered on Mar 21, 2011
3answers
Connecting laptop tip to auto adapter
you may look the jack(tip) show here:
1ecfef4.jpg 1) your car adapter, the red color wire is + pole which connect to the hole of jack(tip), the black wire is - pole which connet to outcover metal of the jack(tip). that is very common.
2) your new jack: check as smae as above. usually white color connect to red color, and black to black is ground connect to outcover of tip.
then you need check again the voltage pole, the tip 's hole should be possitive "+" and the outcover metal is negative "-" pole, it is very important.
hope help you fix it, please feedback any question any time, pleaae take a rating let me know how much helped you thanks!
7/13/2009 6:37:14 PM • HP Compaq tc4400... • Answered on Jul 13, 2009
3answers
Want software HP Compaq tc4400 Tablet
All software/drivers that came with your tablet are available online:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=1849071&lang=en&cc=us&prodTypeId=321957&prodSeriesId=1847962&taskId=135
7/11/2009 10:00:50 AM • HP Compaq tc4400... • Answered on Jul 11, 2009
3answers
I need to know how to turn on a HP X13-04657 LAPTOP, all the lights are on but nothing on the screen.
HP X13-04657, is 2007 PC THOSE this PC has CCFL back lamp strip that is dead.Vista era PC, laptops. are hard to work with now, 17 years old.is this not a HP COMPAQ presario HP X13-04657 (wrong name!) sorry !became HP in 2002. so is HP but manuals are super hard to find now. that x13 is part of the microsoft license code vista. (so is distraction to what it is)the real name of the Laptop is and was Presario CQ61 laptop CQ61 the PC has bottom sticker that shows the real names of PCs.CQ61-219TU is real name of on CQ61, there area many different sub codes, and they are not all the same.CQ61-306AX this had CCFL (cold cathode florecent lamps) that love to fail 3 waysdead, blinks ,dime or yellow = white.was made until 2009 and evolved, to LED backlamps.-410 is CCFLI will answer for CCFL as those just love to fail,but the the test is so easynow the answer for ANY laptop this old. 2007 and older. black screen all the time, and BIOS screens dead, answers only me. here. remove the main battery (large) it simply snaps off the bottom.the power pack is next we run the PC on your power pack AC to DC it must make the screen glow with something, do not use the wrong pack as in mixed up with others.now the lap top seems on, even the fan blows, LED glowpoint a flash lamp at the screen ,dark' room , and of you see any kind of LCD data on the screenthe CCFL lamp below #1 is bad.this is phase 1 testing, as other things can fail too. The keyword below is Mercurythis tells me it is those pesky CCFL glow tubes. 2007 is the year some PC went to LED back lamps. yes I was correct the service manual I did find proves they made both lamp types ccfl-hp07-psnmcz4s4yabbrmds04n13cd-d-0.jpg
4/17/2024 12:37:57 PM • HP Computers &... • Answered 2 days ago
Dove posso scaricare il driver per HP ScanJet 8270? ente compatibile per windows 10...
Question edited for clarity. Question translated to English. We only speak English on this North American website. https://www.google.com/search?q=hp+scanjet+8270+driver+windows+10
HP Scanjet 8270 Document Flatbed Scanner
Hewlett-Packard https://support.hp.com > ca-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner ... drivers free of cost for Windows and Mac ... Windows 10 / ...
Hewlett-Packard https://support.hp.com > ee-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner. This is HP's official website to download the correct ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Download
Softonic https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.softonic.com Download the latest and official version of drivers for HP Scanjet 8270 Document Flatbed Scanner. This driver package is available for 32 and 64 bit PCs. It is ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Free ...
Download.it https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.download.it Download HP Scanjet 8270 Document Flatbed Scanner drivers varies-with-device. Software drivers for the 8270 flatbed model of the HP Scanjet printer. ..
4/10/2024 8:38:39 PM • HP Computers &... • Answered on Apr 10, 2024
2answers
HP 8440P Laptop. I don't remember my password. Help needed for HP 8440p.
This video shows you what to do if you forget your computer password:
4/6/2024 8:00:24 AM • HP Computers &... • Answered on Apr 06, 2024
2answers
How to do a bios recovery on a hp pavilion dv5-1004nr
This video shows you how to restore the BIOS in your computer:
4/6/2024 7:57:59 AM • HP Computers &... • Answered on Apr 06, 2024
Hp dv8 not charging battery
You can follow the steps in this video to troubleshoot your battery:
4/6/2024 7:13:37 AM • HP Computers &... • Answered on Apr 06, 2024
Hp supply central pin connected to the 19V power
  1. Central Pin: In many laptop power supply connectors, especially those using the barrel-type connector, there's a central pin that carries the voltage (typically around 19 volts for most laptops) to power the device.
  2. Voltage and Polarity: It's crucial to ensure that the voltage supplied by the power adapter matches the requirements of your laptop. Most laptops operate on 19 volts, but there are exceptions, so always double-check the specifications of your laptop and the power supply.
  3. Polarity: Additionally, the polarity of the connector is important. The central pin typically carries positive voltage, while the outer sleeve of the connector is the ground (negative). Reversing polarity can damage your laptop, so make sure the connector is inserted correctly.
  4. Safety: Always use the power adapter that came with your laptop or a compatible replacement from a reputable manufacturer. Using an incorrect or incompatible power adapter can not only damage your laptop but also pose safety hazards such as overheating or electrical fires.
  5. Replacement: If you need to replace your laptop's power adapter, ensure that the new adapter provides the correct voltage, polarity, and wattage for your laptop model. It's often safer to purchase adapters from the laptop manufacturer or certified third-party suppliers to guarantee compatibility and safety.
3/30/2024 8:53:24 PM • HP Computers &... • Answered on Mar 30, 2024
3answers
I got a 4 year HP laptop and it show a black screen and if I press Esc it will say Esc..start up and will do the same F2 and others.
If your laptop starts but the screen remains black, this video shows you the troubleshooting steps to follow:
3/27/2024 7:16:54 AM • HP Computers &... • Answered on Mar 27, 2024
What kind of screws open the backside of an HP Envy PC
The screws are T5 Torx security screws. You can get a set of these screwdrivers from any DIY Store or from Amazon. https://www.google.com/search?q=torx+screwdriver+set I have a set like this which has a handle and all the security screw bits. https://www.canadiantire.ca/en/pdp/mastercraft-33-pc-torx-screw-set-0544039p.0544039.html ..
3/13/2024 5:33:03 PM • HP Computers &... • Answered on Mar 13, 2024
How do I open the back of an HP Envy PC, and What kind of screws open the back please.
Great questions, but two questions edited into one. The screws are T5 Torx security screws. You can get a set of these screwdrivers from any DIY Store or from Amazon. https://www.google.com/search?q=torx+screwdriver+set I have a set like this which has a handle and all the security screw bits. https://www.canadiantire.ca/en/pdp/mastercraft-33-pc-torx-screw-set-0544039p.0544039.html ..
3/12/2024 6:00:48 PM • HP Computers &... • Answered on Mar 12, 2024
2answers
What to try now hp omen dv7 battery issue
If calibrating the battery didn't work for you you could try a hard reset of the battery:
3/6/2024 9:11:06 PM • HP Computers &... • Answered on Mar 06, 2024
2answers
I have installed 4G RAM, Is that the MAX supported or may upgrade to more ?
Memory Max Maximum supported = 8GB
2/17/2024 5:55:53 AM • HP Computers &... • Answered on Feb 17, 2024
3answers
I have an HP Pavillion533w that will not turn on when I press the power button.
Here are troubleshooting steps for when your computer won't start:
2/15/2024 7:54:52 PM • HP Computers &... • Answered on Feb 15, 2024
HP Compaq tc4400 Notebook Logo
11 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
connecting laptop tip auto adapter
  • Computers & Internet
