20 Most Recent Samsung Epic Touch 4G 4-G D710 D-710 / Galaxy S2 S-2 White Rubber Feel Snap-On Hard Protective Cover Case Cell Phone for sprint phone only Questions & Answers
0answers
Need manual
Be the first to answer 11/6/2013 11:06:07 PM • Samsung... • Posted on Nov 06, 2013Be the first to answer
Protection appears across screen and wont let me
The media you are using has the recording protection on.
12/15/2009 6:33:19 PM • Samsung... • Answered on Dec 15, 2009
Samsung Maxima 105 zoom
I have the manual. I'll scan it for you & email it. My problem is that the manual doesn't identify the batteries & I lost the ones I'd removed for storage.
2/24/2009 6:16:32 AM • Samsung... • Answered on Feb 24, 2009
Film won't load on Vectis 300 MinoIta
The clue is in your descrition; Old. If the mechanism has jammed, due to age or lack of use that causes tarnisg=hing on the contacts, the motor/mechanism will not load. I would get it serviced at an aurgorised Minolta repair shop. Contact Minolta for a list of authorised repairers.
3/22/2024 7:04:40 AM • Photography • Answered on Mar 22, 2024
I tried to use a 16GB PNYcard in my picture fram and it would not work. It said "No Card" on the screen. What's the answer?
If your picture frame is not recognizing the 16GB PNY card and displaying a "No Card" message, there could be several reasons for this issue:
  1. Compatibility: Some picture frames may have limitations on the size or type of memory card they can accept. Ensure that the picture frame is compatible with SDHC or SDXC cards, as these are the types commonly used for higher-capacity cards like 16GB.
  2. File System: Check if the memory card is formatted in a compatible file system such as FAT32 or exFAT. Some picture frames may not recognize cards formatted in other file systems. You may need to format the card using a compatible file system on your computer before using it in the picture frame.
  3. Card Reader Slot: Ensure that the memory card is inserted correctly into the card reader slot of the picture frame. Sometimes, improper insertion can prevent the device from detecting the card.
  4. Card Compatibility: While SDHC and SDXC cards are generally backward-compatible with devices that support SD cards, some older picture frames may have limited compatibility with higher-capacity SD cards. Try using a lower-capacity SD card (e.g., 2GB or 4GB) to see if the picture frame recognizes it.
  5. Faulty Card or Picture Frame: If none of the above solutions work, there may be an issue with either the memory card or the picture frame itself. Try using the memory card in a different device to check if it's functioning correctly. Similarly, try using a different memory card in the picture frame to see if it's able to recognize it. If the problem persists, there may be a hardware issue with either the card or the picture frame, and you may need to contact the manufacturer for assistance or consider replacing the faulty component.
By following these troubleshooting steps, you should be able to determine the cause of the issue and resolve it accordingly.
3/16/2024 9:30:07 AM • Photography • Answered on Mar 16, 2024
I lost one of the little rubber ball-like feet off my tripod 1612201. Do you have them available?
We don't have anything available Elizabeth. We are Fixya, and we only supply free information. It would be useful to know the maker as the '1612201' doesn't bring much up and looks like a serial number. Your local camera shop can get them, or you can get online. https://www.google.com/search?q=tripod+feet+replacement //
2/9/2024 6:10:43 AM • Photography • Answered on Feb 09, 2024
2answers
Need OptiPix Pro software
I own the OptiPix DPF and here is a pic of the owners manual with directions for the OptPixsetup file. img_20231124_190238_785-45plut3dk5rkrmoi0ue4e000-d-0.jpg
11/25/2023 1:11:02 AM • Photography • Answered on Nov 25, 2023
Smartparts SPDPF84M 8-Inch Digital Picture Frame. I need to purchase a remote for model SPDPF84M. How much will it be please?
Question edited for a lot more clarity, 'make model (what it is)'. Question moved from Televisions to Photography - Digital Photo Frames. $35 for a new one.
SMARTPARTS SPDPF84 Replacement Remote Control
Remotes.net https://www.remotes.net > products > replacement-rem... The RTSPDPF84 is a custom-built replacement remote control to the original SMARTPARTS SPDPF84. It will perform all the functions that the original ... US$34.90
Replacement Remote Control for SMARTPARTS ...
Amazon.com https://www.amazon.com > Replacement-Control-SM... This is a custom built replacement remote made by Redi Remote for the SMARTPARTS remote control number SPDPF84. *This is NOT an original remote control. US$34.95 ..
11/25/2023 12:40:58 AM • Photography • Answered on Nov 25, 2023
Driver for target australia film scanner f100
I own the Target AU F100 film scanner and have the original CD. It has a Driver directory on it, which includes DriverInstaller app and 32 and 64 bit subdirectories. It installed recently on my Win 10 64 bit PC and worked ok, despite being Win XP/Vista software vintage 2010.
6/14/2023 3:09:06 AM • Photography • Answered on Jun 14, 2023
4answers
Does black and white photography use the same
Yes
2/21/2023 7:16:33 PM • Photography • Answered on Feb 21, 2023
WHAT DOES 3 FLASHING RED LIGHTS MEAN ON MY POLIROID INSTANT 300 CAMERA
The solution to red flashing lights on Polaroid 300: We fixed the problem. Check the +ve terminal on the lower set of batteries. Ours wasnt connecting so we stuck in some tin foil and it works.... plastic strips and all in their proper place!
1/22/2023 4:03:31 AM • Photography • Answered on Jan 22, 2023
Samsung Epic Touch 4G 4-G D710 D-710 / Galaxy S2 S-2 White Rubber Feel Snap-On Hard Protective Cover Case Cell Phone for sprint phone only Logo
4 questions posted
Top Samsung Photography Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Samsung Photography Expert? Answer questions, earn points and help others
View Most Popular
Samsung Photography
  • Samsung Photography
Most Popular Question
am looking original owners manual
  • Photography
