20 Most Recent Canon PIXMA MP510 All-In-One InkJet Printer Questions & Answers
2answers
My photos have a stripped background, but
Run Nozzle Check first. Is the nozzle perfect?. Usually little unperfect nozzle pattern does not make significant effect on text quality but in photo quality it does.
4/28/2022 3:16:02 AM • Canon PIXMA ... • Answered on Apr 28, 2022
2answers
Canon MP 510 paper jam
I had the same problem and found a small coin in the back feeder. Remove the back coverplate and tip the machine onto its back and give it a good shake. You might be surprised at what falls out.
12/1/2021 12:27:19 PM • Canon PIXMA ... • Answered on Dec 01, 2021
I am getting a B200 error code on my canon
The error in Canon Printer Error Code B200 indicates a defective print head. A print head is an element that actually allocates the ink onto the paper from the cartridges, which ensures that it is one of the most critical aspects of the printer as a whole. Canon Printer Error Code B200, which can signify a hugely damaging system error, is one of the most feared. Try these fixes before you go replacing your entire device. Follow this step given below. 1. Restore the doubtful cartridges 2. Extract and clean your printhead 3. Reseat your printhead 4. Check for obstructions Solution - Canon Printer Error Code B200
9/25/2020 6:48:17 AM • Canon PIXMA ... • Answered on Sep 25, 2020
2answers
SERVICE ERROR B200
Canon Printer Error B200 has tried Canon printer users quite frequently. However, the good point is that there is a method that you can follow for managing and repairing this error. A reliable guide for troubleshooting can change the user's fix the Error Code B200. Easy & Simple ways to Resolve Canon Printer Error B200. 1.Re-boot printer. Un-plug your printer and give it cut for at least 30 minutes. 2. Eliminate any blocking. There's a chance something is interrupting the joint to your printer head. 3. Cleaned printer head applying your Computer printer maintenance options. To Resolve Canon Error B200, you want to join with Printer Error Support specialists. Full Blog - Canon Printer Error B200 0_rwlma5mq2bbnwyse-undefined-undefined-0_27.jpg
8/28/2020 3:51:25 PM • Canon PIXMA ... • Answered on Aug 28, 2020
3answers
Does not print error b200
Helo, found on web. Good Luck :0)
The error code is standard for many of the late model MPxxx printers. The B200 error is "Printhead Temperature exceeded", What this means that while you were printing some document, either one or more of the printhead ink wells ran out of ink and the printing continued. Printhing without ink in the wells will OVERHEAT THE PRINTHEAD NOZZLES and can potentially burn the out. The printer has a built in temperature sensor to detect the ambient temperature and to monitor the temperature of the head. This data is always collected and monitored and saved in the EEprom data and the Service Test print data.
If the error will not go away once you have unplugged the priner for at least 5 minutes, then there is the possibility that you have already burnt out the head. Remove the printhead and use a 5x magnification glass to look VERY CLOSE at all of the nozzles to see if you can detect any possible burnt out nozzle.
It many come down to need a new printhead.
HERE IS THE LINK, IF YOU HAVE PROBLEMS.
http://www.fixyourownprinter.com/forums/laser/13864
6/2/2020 8:28:37 AM • Canon PIXMA ... • Answered on Jun 02, 2020
Small torn piece of paper jam
After getting out my instruction book and further assessing the problem, was able to remove a small corner of the paper and then the printer ejected the remainder.
3/7/2019 7:04:31 PM • Canon PIXMA ... • Answered on Mar 07, 2019
Need to print only black ink on canon mp510
in the printer set up ( normally in the print section , change the color to black and white , make default and ok
1/1/2018 9:08:56 AM • Canon PIXMA ... • Answered on Jan 01, 2018
How to clean printer head mp510
Go to a program you can print out of, click 'file' then 'print' then 'printer properties' then 'maintenance' and you'll find 'clean' and 'deep clean' buttons there.
3/2/2015 11:59:44 PM • Canon PIXMA ... • Answered on Mar 02, 2015
2answers
Error6800 mp510
The error 6800 means you need to replace the logic board.This is the code of the logic board (QM2-3827).If i have been useful please give me a vote :)
10/20/2014 2:09:24 PM • Canon PIXMA ... • Answered on Oct 20, 2014
0answers
Why has my printer it won't come on at all
Whilst the obvious answer is to plug it in, I think that there are some words missing from the question between "printer" and "it" - can you clarify?
8/8/2014 6:02:34 PM • Canon PIXMA ... • Answered on Aug 08, 2014
Orange/green lights flashing on canon mp 510. computer says not connected but all leads in place. can i fix this
I would suggest switching everything off, unplugging and starting all over again, it may be that simple. Plan B :Un-install the driver and reinstall. Plan C :Check that the MP510 is the default printer via Control Panel/Hardware & Sound/Printers. Click printer icon and then right click or use task bar. The flashing lights indicate a fault on the printer itself so check for paper jams, ink cartridges in place etc.
6/28/2014 7:28:45 PM • Canon PIXMA ... • Answered on Jun 28, 2014
2answers
How to get scanner to attach to e mail
Operate the scanner from the computer not the printer. Have you loaded the MP Navigator progam from the cd supplied with the printer? If not, do that first and then follow the steps below. Double click MP Navigator icon on desktop. Choose "custom scan with one click " Save to pc. (" attach to email "only works on windows mail) Open saved location and rename. Write your email & click on insert drop down box Click on "pictures inline " Open pictures. Open MP Navigator folder Choose scanned item by name Click on open box Scan will appear under the text in your email.
5/31/2014 8:10:28 PM • Canon PIXMA ... • Answered on May 31, 2014
0answers
Draivar
Be the first to answer 5/21/2014 11:07:49 AM • Canon PIXMA ... • Posted on May 21, 2014Be the first to answer
I CANNOT TURN ON ?
Check you power cord and your outlets too.
4/25/2014 10:07:37 AM • Canon PIXMA ... • Answered on Apr 25, 2014
0answers
0answers
Error E05
Be the first to answer 3/5/2014 3:30:25 AM • Canon PIXMA ... • Posted on Mar 05, 2014Be the first to answer
0answers
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
426 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
get scanner attach e mail
  • Office Equipment & Supplies
