20 Most Recent
Xerox Phaser 3124 Printer Questions & Answers
How to reset xerox 3124. The test pages says
is not the method of refilling problem^^ actually it has something u dinnot change. the toner shouldn't has any problem, the problem is the resetting. once it reset, even empty toner cartridge also can print.
Toner low indication
Take out toner and shake up down . And put it again. may it will help you . Else let me know.
Refill
buy a new one. you can't refill it
Xerox3124 jammed paper
HiOpen and close the front cover.Turn the printer off and on.This automatically exits the paper from the printer.You can also remove the stuck paper by gently pulling it out straight.If there's no stuck paper,clear any print queues.Disconnect the printer completely from power and then re-connect again.Now try printing.
