20 Most Recent
Dell D520 Notebook Questions & Answers
Iwant audio drever
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=LATITUDE%20D520&os=WW1&osl=en&catid=&impid=
try on this page, select your operating system and go
2/22/2011 6:06:19 PM •
Dell D520...
Answered
on Feb 22, 2011
I have a latitude XT,
It sounds like your default profile might have become corrupted. You can make a new profile and transfer your information to the new profile. But before doing that try scanning your computer for virus's amd malware infections.
If you do try the new profile and plan on transferring your information from one profile to another make sure that the old profile is not password locked. Or transfer the information through the Administrator login.
Best of luck...
11/22/2010 3:59:03 PM •
Dell D520...
Answered
on Nov 22, 2010
Same as above, with my laptop being studio XPS 1640
Well, as long as your pc is under warranty, Call Dell and have the keyboard replaced. it takes 24 hours to order the part, and 15 minutes to replace it. By this time tomorrow, you could be all set like a new 'vette. Good Luck!
8/31/2009 11:44:16 PM •
Dell D520...
Answered
on Aug 31, 2009
I have an Inspiron 1525 Dell Laptop with windows
You may have a bad connection. You could try taking the keyboard off and unplugging it, then plugging it back in.
If that doesn't work try using a usb keyboard and see if you're able to type. If you can type, try changing the laptop's keyboard, and if you can't type you may have a currupted OS.
If none of these are the problem, you have a bad keyboard port on your motherboard.
7/3/2009 4:57:09 AM •
Dell D520...
Answered
on Jul 03, 2009
Number keys not working dell laptop
have you or anyone spilt liquid on the keyboard?
do you regularly clean your keyboard?
sorry for the obvious questions but you would be suprised how much chaos it could cause....
here are a few checks for you to do (if you can use a usb keyboard)
1) clean your keyboard of moisture, dirt and grime
2) check your antivirus to do a scan to ensure that the keyboard drivers havent been corrupted by a virus
if still the same then:
3)remove the keyboard and look for corrosion on all pins and/or conectors (corrosion will be a greenish/white color)
if corrosion is found then use a solution (cheapest being vinegar) to clean the pins and/or conectors
if still the same then your keyboards driver maybe corrupt, if so then
download the driver from dell's driver site and install, after the
instilation do a create restore point or back up your drivers (id put
them on a dvd r disk myself) and keep them for future reference.
if this doesn't sort out the problem then it's definately a hardware failure, which means fail......
hope you sort the problem out soon....;-)
4/27/2009 11:13:08 PM •
Dell D520...
Answered
on Apr 27, 2009
Keyboard not working
Hi Simran
Hope you are doing good.
Please try the following solution.
Press Fn (Function button) on the left bottom side of your keyboard that is between the left Alt and thw windows key and while holding it down press the Num Lk key on the top right side of your keyboard. It is between the Prnt Scrn and Pause button.
Please chcek your keyboard and advise if it works fine now or not.
6/14/2007 9:13:30 AM •
Dell D520...
Answered
on Jun 14, 2007
I want to know about some adventures video games?
Check out Big Fish Games. It is a subscription service but they have all types of games including adventure and hidden object. You can also tryp Pogo since they have both a fee and subscription service. Last, but not least, you can try one of your local computer stores or the electronics section of "big box" stores like Target, Walmart, Kmart, etc.
