20 Most Recent Westinghouse LTV32W6HD 32 in. LCD Television Questions & Answers
Contact a TV repair shop.
Westinghouse... | Answered on Jul 25, 2017
Gustav, Try factory reset, to get to the Setup Wizard. With the TV on press the menu button on your remote. While the menu is displayed press the 0 button four times. This should bring up a new menu with factory reset as an option.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.hdtvsolutions.com/pdf/27w7_32w6_37w2uMan.pdf
Westinghouse LTV 32w6 User Manual
How do you factory reset Westinghouse lcd tv AskReddit
http://www.avsforum.com/forum/166-lcd-flat-panel-displays/678671-new-offical-westinghouse-ltv-27w7-ltv-32w6-ltv-37w2-thread-87.html
Westinghouse... | Answered on Mar 21, 2017
The tv have three colors guns Green,Red,Blue.Pink pictures mean there no blue color.Take another tv tries that incomming broadcasting signal cable,see if u getting all three right colors for that tv?Yes,than that tv have a pink pictures have a dead Tuner signal board,no than u have a bad incomming broadcasting signal cable or pay cable box.If it the tv Tuner signal board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Westinghouse... | Answered on Sep 02, 2014
If the picture goes bad after about 15~30 minutes, then more likely to be bad LCD controller bd. See sample of the failed LTV-32W3HD here: http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Parts: http://www.shopjimmy.com/catalogsearch/result/index/?q=LTV-32W6HD&limit=200
You can try running the TV with the back open with a small fan blowing in the back to keep it cool just to verify that it is heat related.
Backlight problem. Check and replace damaged component/s at its backlight inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
Westinghouse... | Answered on May 23, 2014
Have you tried resetting the TV's settings to the factory default?
You should be able to do that within the settings menu on the TV.
Westinghouse... | Answered on May 02, 2014
Sounds like a T'Con fault. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Westinghouse... | Answered on Apr 01, 2014
do you still have it i'll but whole thing depending how far and cost to ship
Westinghouse... | Answered on Dec 07, 2013
Format does not supports. That's all. Refer its user manual for details.
Westinghouse... | Answered on Sep 25, 2013
unit is incompatable in some way
Westinghouse... | Answered on Nov 09, 2012
Power supply problem
Westinghouse... | Answered on Oct 07, 2012
This is not uncommon for the type of supply used in modern sets called a 'switched mode power supply.'One of the failure modes is an audible squeal. These operate normally way above the range of our hearing but is getting sick, they holler at lower frequencies.This kind of marginal operation is a harbinger of complete failure of the main power supply often due to a part called an electrolytic (chemical) capacitor that is nearing death.These parts cost a few pennies and should have cost a few more to insure quality but most companies couldn't care less since they will generally outlive the warranty period.
Westinghouse... | Answered on Feb 03, 2012
If your TV has an On-screen Menu you should be able to access your Tuner controls. Run your auto channel scan and you should pick up your "regular channels". You may be able to de-select the odd channels and show only the ones you want to use.
Westinghouse... | Answered on Nov 07, 2011
not on a surge protector is it? could be tripped....if not, it should have been. some have a built in breaker, unplug it for a couple of minutes and plug it in and try it.
Westinghouse... | Answered on Feb 26, 2011
In sounds like the tuner might be going out, try to use the RCA, input connectors.
Westinghouse... | Answered on Feb 21, 2011
It can be the main board is bad and not sending the signal to turn on the rest of the power supplies, or the power supply is bad and not supplying the correct voltages to the main board, so you need to inspect the two boards.
Boards for your TV: http://www.shopjimmy.com/catalogsearch/result/?q=Westinghouse+LTV32W6HD+
Please read my guide first.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Westinghouse... | Answered on Jan 27, 2011
Westinghouse LTV32W6HD 32 in. LCD Television Logo
60 questions posted
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Westinghouse Televison & Video
Most Popular Question
stay channel
  • Televison & Video
