Master pin reset
We've received many emails from GPS users who say they have lost their PIN code.
For those of you that don't know what a PIN code is:
Some GPS manufacturers provide a feature, which allows the GPS owner to assign a unlock access code or PIN to their GPS.
The PIN is designed to prevent your GPS from being used by an
un-authorized user. It was also meant to be used a a deterrent to
thieves, making the GPS useless if stolen.
When you set up the PIN, you will be asked to enter in a code. After you
enter the last digit, you will be asked again for the code. This is to
make sure that both entries match and verifies that the PIN that you
requested will be the one written into memory.
Your PIN is written into non-volatile memory..... it's not a file that
is accessible via USB communications between the GPS and a PC. You can't
clear it by disconnecting the power or disconnecting the battery or
letting the battery run down. There is no jumper or switch inside the
GPS to reset it, so don't waste your time tearing your GPS apart in an
attempt to clear it.
Now, after you set the PIN, you will be asked to set the "secure"
location. This can be anywhere.... your work location, home, local gas
station, school, etc. In order to set the secure location, your antenna
must be up and you have to have a satellite lock. If you don't have a
lock, the "set" key will be grayed out until you acquire a lock.
The secure location is your "back-up key" in case you forget your PIN.
If you have forget your pin, all you have to do is physically go to the
secure location. Make sure your antenna is up and that you have a
satellite lock. When you are in the secure location, your GPS will NOT
ask you for the PIN when you turn it on. You'll then be able to reach
the main menu and change the PIN and secure location to something else
if you desire.
If you have forgotten both the PIN and secure location, you are out of
luck. You'll have to send your unit back to the manufacturer to have it
unlocked. The manufacturer may charge you for this service.
Note: If you do send the unit back to the manufacturer to be unlocked
and you are found not to be the original & rightful owner of the GPS
and it's determined to be stolen, the manufacturer may contact law
enforcement (they're policy on this is right on their website under
FAQ's).
