20 Most Recent OKI B6500 Led Printer Questions & Answers
OKI B6500 has ID mismatch error
Basically the machine does not recognise the image drum. You maybe using the Xerox equivalent which of course wont work. Replace the drum with an OKI one and it should work even though its really a Xerox printer.
12/7/2017 7:51:46 PM • OKI B6500 Led... • Answered on Dec 07, 2017
NVRAM Failure oki
OKI provides live customer support 24/7 at 1-800-OKI-DATA (1-800-654-3282) in addition to a live chat feature during "normal" business hours. Visit www.okidata.com and look for the red "chat" button on the right. The skilled technical support staff should be able to fix your problem promptly.
1/19/2017 10:27:25 AM • OKI B6500 Led... • Answered on Jan 19, 2017
2answers
OKI B6500 display loading on the screen then it stops there.what can i do to solve that problem?
problem on LSU please replace it
11/1/2016 7:05:00 PM • OKI B6500 Led... • Answered on Nov 01, 2016
Oki b6500 is stuck on initializing
the main board needs to be replaced
10/27/2015 10:33:01 AM • OKI B6500 Led... • Answered on Oct 27, 2015
Delete print jobs
open print driver and in the status window right click and select cancel print or when printer is running print job press cancel button
10/27/2015 10:30:29 AM • OKI B6500 Led... • Answered on Oct 27, 2015
Why is my printer only printing a black sheet of paper?
Hi it is not the toner but it could be a developing unit or transfer roller. But since on b6500 the developer unit is changed with the toner it is probably the transfer roler or HV unit. Regards
4/10/2015 5:27:41 PM • OKI B6500 Led... • Answered on Apr 10, 2015
Ep catridge prints smodges
Well it can be a dirty led head use a wet towel and clean it it is located usualy on the bottom site of the upper cover right above the drum. The second thing that can be if you are facing lines on every print that means the image drum is out.
11/26/2014 6:02:44 PM • OKI B6500 Led... • Answered on Nov 26, 2014
Smudging
Clean the LED head and rollers with Isopropyl alcohol.
11/25/2014 5:51:55 PM • OKI B6500 Led... • Answered on Nov 25, 2014
manual
0answers
4answers
ROS failure
Hola buen dia OKI B6500 la falla que presenta es ERROR DE ROS crei que era el laser scaner pero le puse el de otra impresora en buen estado y nada siguio al poco tiempo igual de hecho el que le quite lo puse en la impresora que esta en buen estado y sigue funcionando, este error OKI B6500 lo hacen muy comunmente este tipo de impresora,En OKIDATA me comentaron que lo provocan varios sensores sobre todo el de tapa superior pero aun que lo corrijas funciona pero al poco tiempo lo vulve hacer que mas puede ser si ya le cambien el sensor de tapa sup.,laser scaner,sensor de deteccion de toner., en OKI no especifican cual es el provoca este error nada mas dicen que son varios sensores.
NOTA: de hecho un colega hizo lo mismo y no le la corrigio lo que hace es la apaga varias veces sacando y poniendo el toner y a veces bingo funciona de hecho tiene una impresora que inicia bien pero al poner el toner se apaga o marca error que hacemos las tiramos tienen menos 80,000 paginas alguien tiene un buen TIP
6/6/2014 8:57:48 PM • OKI B6500 Led... • Answered on Jun 06, 2014
OKI ES7120 loading on LCD display
Needs firmware upgrading
5/14/2014 9:47:55 PM • OKI B6500 Led... • Answered on May 14, 2014
0answers
0answers
What is an Engine NV Failure
it means nevada emissions control program
4/23/2014 12:18:47 PM • OKI B6500 Led... • Answered on Apr 23, 2014
Impresora oki b6500
oki b6500 code flash error firmware upgrade que puedo hacer
2/28/2014 12:46:21 AM • OKI B6500 Led... • Answered on Feb 28, 2014
Error 02?
this is a clutch problem logging into compartment 1, replace clutch
2/13/2014 12:11:32 PM • OKI B6500 Led... • Answered on Feb 13, 2014
OKI B6500 Led Printer Logo
99 questions posted
Popular Products
Top OKI Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
B OKI
  • B OKI
Most Popular Question
oki b6500 display loading screen stops
  • Office Equipment & Supplies
