20 Most Recent
Ricoh Aficio SP C811DN Laser Printer Questions & Answers
Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
Error Code SC580 on Ricoh Aficio SP C811DN
First try switching off and on the printer to reset the error.
If still there the error check the following;
- Check CN983, it may be disconnected on the IH inverter.
- Defective IH inverter - replace IH inverter.
- Defective IH coil unit - replace IH coil unit.
It is a bit complicated to repair these parts.
Better to contact an engineer.
Goodluck and please rate me, thanks.
Error 863-06
format the drive from the machines system and restart.
if this does not work call 0243494871 for the part or any other ricoh technician for help.
thanks and all the best
How do i fix the error message set pcu correctly on my ricoh aficio sp c811dn
Turn the machine off. Open the access door and remove the cyan photoconductor unit. Check the contact pins are straight and undamaged. Gently reinsert the unit. Turn the power back on. If the machine still does not recognise the pcu is inserted it is probably damaged and needs replacing. How many copies/prints has your machine done?
My ricoh sp c811dn suddenly started displaying the
Here is a way to reset but make sure you follow the instructions correctly.
turn off machine
press online and escape buttons together whilst turning on machine,
when display comes up wait till three options are listed, use arrow button down to select engine, use arrow right to select mode(5.mode) and ok, left arrow to 5.810 SC RESET. OK. PRESS OK AGAIN AND THEN EXECUTE AT BOTTOM OF SCREEN.
Turn off printer and wait ten secs then turn back on.
If only temp error this should reset and start up again, Good luck
Service manual
go on line to the manufacturer and look up your model and down load the service manual
Ricoh SP C811DN has a sc 400 error code
open the front door and left door, take out the drum unit after releasing the lock lever if look at the opening from the right you can see a black sensor unit facing inward towards drum clean its inner side with a dry cloth and put back everything it is the id sensor, machine should work now
Error sc549
fuser encoder error
-replace Encoder Ferrite core switch - B2234240
-replace Photo interuppter - Horizontal 7mm AW020190
