20 Most Recent
Samsung SyncMaster 204B (Silver, Black) 20.1 inch LCD Monitor Questions & Answers
Samsung syncmaster 204b not turning on-
My
in near your monitor u find any metallic product than you please remove the the monitor and plug in another side if your problems is steel not solved than you please contact samsung service center regarding this issue...........
12/17/2010 11:14:52 PM •
Samsung...
Answered
on Dec 17, 2010
Samsung syncmaster 204b not turning on- My
With certain Samsung models, not only do the capacitors go, but the MOSFETS will go as well, possibly a fuse. The MOSFETs are the big bulky black things with a silver tab and three legs. Should be between the capacitors and the transformers. Just pull those both out and test them (Google "test MOSFETS") One is probably bad but they must be replaced in pairs.
12/17/2010 4:36:22 PM •
Samsung...
Answered
on Dec 17, 2010
My SyncMaster 204B 20.1" suddenly died. One moment
Caps have completely flat tops, bad caps can also look normal but can have high ESR (Equivalent Series Resistance).<br />
What voltages are you getting at the secondary DC power supply side measure directly on those caps?<br />
<span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"> <a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br />
<span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a><span style="mso-tab-count: 1"> </span></span><br />
<span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <span style="mso-spacerun: yes"> </span><a href="http://lcdalternatives.auctivacommerce.com/">http://lcdalternatives.auctivacommerce.com/</a><span style="mso-spacerun: yes"> </span>he can make you a set of caps for you.</span><br />
9/22/2010 9:46:30 PM •
Samsung...
Answered
on Sep 22, 2010
Samsung monitor picture clicks off after 2-5 seconds...
Yes, It sounds like the backlight inverter circuit is shutting down. No inverter power, no backlight. On some monitors the inverter circuit will shot circuit the power power supply which makes the power light flash on some it just kills the backlight. You can usually check with a flashlight. Hold the flashlight pointed at the screen and see if you can see any of the icons or background picture. If you can then it is the backlight circuit or backlight tubes, usually the circuit.
Buddy
6/17/2010 8:36:57 AM •
Samsung...
Answered
on Jun 17, 2010
How i can fix my 21.5
Set your screen resolution to 1600 x 1200, the native resolution of the screen.
10/11/2009 2:05:38 PM •
Samsung...
Answered
on Oct 11, 2009
With all cords hooked up there is no pic and a
This means you are not getting a signal to the monitor.
If you have 2 SVGA outlets on the back of your computer, are you using the correct one?
Next, I would suspect that the display on your video is out of range for the monitor. On the computer start-up, start hitting the F8 key until you get the black and white menu. Choose the VGA option to get Windows started and then you can set the correct resolution.
9/30/2009 6:33:23 PM •
Samsung...
Answered
on Sep 30, 2009
Screen Resolution problem
Different video cards offer different ways to deal with a user's screen. ATI, and others, for instance, offer a "virtual desktop", which does what you're describing. You get to the settings that control this feature from the Personalize->Display Settings menu options. Here you'll also find the different resolutions your video adapter supports. If the 1600 x 1200 resolution is listed, then I would remove the existing driver for both the adapter and the monitor, and reboot the machine. On startup, Windows will most likely detect the "new" hardware (actually, your existing ones) and will go through the process of finding the appropriate drivers for your adapter. Good luck!
8/16/2009 9:00:12 PM •
Samsung...
Answered
on Aug 16, 2009
Screen is black and power button is blinking
It sounds like you have a monitor with a common problem. After a few years some LCD monitors
will blow a power supply. The problem is caused by parts called
capacitors overheating in the confined space of the monitor. If you are
good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site
www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work
fine. The capacitors do need to be installed with the correct + and -
connections, note the stripe on the old one and insert the new one the
same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.comOver 21 years of computer and printer support/repair
8/7/2009 3:28:50 AM •
Samsung...
Answered
on Aug 07, 2009
Power light is blinking and the screen is blank.
It sounds like you have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of the monitor. If you aregood at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site
www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should workfine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one thesame way. Ifyou don't want to try the repair yourself we offer a repair service for $35 plus shipping.
Buddy
Corporate Computer
7/23/2009 10:00:28 PM •
Samsung...
Answered
on Jul 23, 2009
How to fix pink colur screen on sync master 794 mg samsung
The connecting cable or the video card would be the first suspects. Try a different cable to connect the monitor first, if there is no change, the video card in the computer would be second to look at. Can simply connect a different monitor to your computer to troubleshoot this. If the testing monitor works, it will be the graphics card that is the issue.
6/19/2022 1:41:48 PM •
Samsung...
Answered
on Jun 19, 2022
