20 Most Recent Sony BRAVIA KDL52XBR2 Television Questions & Answers
Sony Bravia periodically has loss of sound. Sound
HI MAIN BOARD OF THE LED IS DEFECTIVE MEAN AUDIO SECTION GOT SOME PROBLUM PLEASE REPLACE MAIN BOARD THANKS M NASIR
10/2/2021 5:49:51 PM • Sony BRAVIA... • Answered on Oct 02, 2021
After lightning struck 20 feet from house the
Serious! If the TV is new, you may check your homeowners insurance for a replacement. The Power company can Verify the power fluctuation for you. When an appliance receives a Power Surge like that, the sensitive electronics are damaged or weakened. For PROTECTION: Get a 1000Watt UPS and use it between the house power and the TV. http://www.tigerdirect.com/applications/SearchTools/search.asp?lowprice=50&highprice=99.99&keywords=1000W%20UPS&cat=&mnf= Try This.
2/17/2018 7:08:30 PM • Sony BRAVIA... • Answered on Feb 17, 2018
2answers
I have a Sony Bravia LCD Flat TV. About 2 months ago small horizontal lines appeared. They are rainbow in color. Now many more have appeared...it is getting much worse. The plastic front is actually m
Sounds like the TV may be hooked up to a source with too much voltage, or getting overpowered in some other way. This is a safety hazard; if it's hot enough to melt the screen cover, it's hot enough to explode without warning. This isn't something you should try to fix yourself; call it in for servicing if you can. In the meantime, you should keep it unplugged.
1/31/2018 12:12:15 AM • Sony BRAVIA... • Answered on Jan 31, 2018
0answers
New TV that is not a SONY due to poor firmware
The three top Best Buys in Which? magazine were all Samsung. So that sounds good.
3/23/2014 8:38:39 PM • Sony BRAVIA... • Answered on Mar 23, 2014
Moved Sony Bravia TV, now will not turn on at all
The warranty on this set should be for 1 year. Return it for warranty service. Unless the set was dropped, moving it should not have effected anything. DO NOT open the set sas that would void the warranty.
Dan
3/13/2014 2:17:46 PM • Sony BRAVIA... • Answered on Mar 13, 2014
0answers
My Sony Bravia kdl32ex43b has 6 blinking standby
6 blinks denotes a fault with its main board. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
10/18/2013 2:21:28 PM • Sony BRAVIA... • Answered on Oct 18, 2013
0answers
Sound but no picture
You can find the information about this problem in user manual
9/24/2013 12:27:12 PM • Sony BRAVIA... • Answered on Sep 24, 2013
Sap
Set the MTS option to "Auto SAP". See page 35 of the manual at http://www.docs.sony.com/release/KDL52XBR2.pdf
6/11/2013 5:58:29 PM • Sony BRAVIA... • Answered on Jun 11, 2013
2answers
My Sony Bravia remote control is slowly loosing it's functions.
You can repair some of these remotes. Usually the hard part is getting the cover off. they are not really made to be serviced. The problem with most all remotes that start doing what you describe is either wear or something spilled on it. You can fix it. Sony remotes may have 1 screw in the battery compartment. remove it and try sliding the front and back. If that dosen't work try prying from one side with a sharp edege. If you do manage to get it open take the PC board out. You will see a rubber like membrane that lays against the board. Try cleaning that with a qtip and rubbing alcahol. Then clean the PC board the same way especially where the pads of rubber contact the board. Make sure it's completely dry and snap it back together. If it works better good, if not the pads are to worn and you just have to replace. Good Luck.
3/24/2013 10:07:21 PM • Sony BRAVIA... • Answered on Mar 24, 2013
I have purchased Sony Bravia
my sony bravia BX42 has a color green horizontal line and it makes bigger and bigger until some color pink was appeared then I am worried if it will not turn to normal as it goes :(
6/5/2012 12:56:11 PM • Sony BRAVIA... • Answered on Jun 05, 2012
Sony Bravia KDL46W4150 crackles and volume suddenly increases
HelloThere is some loose solderings or leaky ceramic capacitors at the audio output section of your sound card. Check it.
2/28/2012 3:17:17 PM • Sony BRAVIA... • Answered on Feb 28, 2012
HOW DO i TURN OFF SAP ON MY BRAVIA KDL-V32XBR1
Find out where the "audio settings" menu is. Make sure the audio settings is set to "Stereo", instead of SAP.manual at link below....http://www.retrevo.com/support/Sony-KDL-52XBR2-TVs-manual/id/274bh528/t/2/
10/11/2011 5:02:16 AM • Sony BRAVIA... • Answered on Oct 11, 2011
2answers
TyLast couple of weeks have
That sounds like an antenna problem. Try moving your antenna around and rescanning the channels.
6/13/2011 8:35:22 PM • Sony BRAVIA... • Answered on Jun 13, 2011
I have a 32 V
This problem can be fixed by Qualified Technician.don't worry your LCD Screen is alright and this is not a big issue.
6/13/2011 2:28:18 PM • Sony BRAVIA... • Answered on Jun 13, 2011
Sony BRAVIA KDL52XBR2 Television Logo
101 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
new tv not sony due poor firmware
  • Televison & Video
