20 Most Recent Canon PIXMA MP530 All-In-One InkJet Printer Questions & Answers
10answers
Error is inner cover is open.
The "inner cover" can be seen if you open the paper output door, which you have to do to open the "printer cover" to get inside the machine and install the ink cartridges. The inner cover is a black bar right inside here. Push it up firmly enough , and it will snap up.
Regards,
Sai.
9/30/2023 3:42:24 AM • Canon PIXMA ... • Answered on Sep 30, 2023
4answers
How do I deal with
Solution 1:
  • Remove and replace the cartridges.
Solution 2:
  • Insert new cartridges
Solution 3:
  • Reseat the print head to correct print issues or clear an error.
Solution 4:
  • The print head is broken and it must be changed by a new one.
Source:
http://fix-your-printer.blogspot.com/2010/11/error-u052-on-canon-printers.html
11/21/2022 10:29:09 PM • Canon PIXMA ... • Answered on Nov 21, 2022
Canon Pixma MP530. I'm having issues with error Code:15,230,0 on Mac 12.1. I have reset the printer settings and installed needed drivers and I'm still getting this error
Question edited for clarity, MP530, not MX. Question moved to Canon Pixma Printers. Drivers Error, but looks like you know that. https://www.google.com/search?q=Code%3A15%2C230%2C0 Remove the printer from the MAC. Go here and get new Firmware and then Drivers as a new package. https://www.usa.canon.com/internet/portal/us/home/support/details/printers/support-inkjet-printer/mp-series/pixma-mp530?tab=drivers_downloads ..
2/12/2022 8:11:10 PM • Canon PIXMA ... • Answered on Feb 12, 2022
How to set ink cartridges?
How To Replace Cartridge(s)
  1. Lower the Canon PIXMA MP530 printers front cover and output tray. You should also lower its paper output cover to open.
  2. Then, wait for the head cover to open. ...
  3. Push down the empty cartridges lock lever. ...
  4. Slide the new cartridge to its correct slot.
1/7/2022 3:17:35 PM • Canon PIXMA ... • Answered on Jan 07, 2022
Canon mp520 makes a horrible noise and displays code 5100
Canon printer is one of the best brands in the world many big organisation are relying on the canon printer, its unmatched printing quality and versatility makes it more best printing devices in the world, but every machinery devices causes problem, but don't worry we have a proper solution, Kindly visit us to get the proper solution How We Support: 100% Fully Assistance We Are Available 24*7 We Work Fast as per Customer demand For More Info Do Visit Us: canon printers error code 5100 Toll-Free No: +1-888-633-7151
9/12/2019 9:06:31 AM • Canon PIXMA ... • Answered on Sep 12, 2019
2answers
I want to throw away
If you're throwing it away, take a hammer to it. Once it's been fairly well destroyed, you should be able to find the memory card, and trash it. If not, trash all the internal boards. This has the added benefit of letting you work off a little everyday annoyance.
That's the simplest way, and the way the DOE/DOD does it, as well as many corporations....except they use an industrial shredder.
3/25/2019 1:37:38 AM • Canon PIXMA ... • Answered on Mar 25, 2019
Cannon mp530 won't print magenta, changed
Hi. That happens sometimes with generic cartridge. It seem that print head is defective.
2/19/2018 1:17:55 PM • Canon PIXMA ... • Answered on Feb 19, 2018
2answers
Ail.comI have a canon
PIXMA MP530 Linke to manuals, and free Canon telephone number and email support.
1/27/2018 3:04:34 PM • Canon PIXMA ... • Answered on Jan 27, 2018
2answers
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
1/15/2018 5:39:39 AM • Canon PIXMA ... • Answered on Jan 15, 2018
4answers
Error 1681 more than one Cyan cartridge installed
I have the same issue as well - I just open the printer, pop out the cyan cartridge, and reinsert it (the same one). This generally works - sometimes I need to do it once or twice. I figure I'll be patient and keep doing this until I a) finish the cyan ink cartridge, b) replace it out of annoyance, or c) through the printer out the window in total frustration.
Interesting to hear about "faulty" cartridges though - I shell out for the "authentic" Canon cartridges which you would think would be reliable - maybe I should switch to using the imitation ones if I'm going to have issues with them anyway...?
12/8/2017 8:51:10 AM • Canon PIXMA ... • Answered on Dec 08, 2017
My computer can not find my new wireless printer.
Check the Lan/Wlan settings on the printer. Set to DHCP for address and reboot the printer. This should ensure the machine is getting it's IP address from your router. Recheck the IP address and subnet mask are in the same range as your computer and router and try a test print. If that does not work - manually set an address in the printer with a terminal value of 50 eg 192.168.0.50. Try that. If still no good, reset the printer IP to DHCP automatic and reboot the entire system. Please note if you are using Apple/Mac portable computers - your IP address range may change every time you boot in a different location.
12/6/2017 6:15:21 AM • Canon PIXMA ... • Answered on Dec 06, 2017
2answers
Error 5110 for Canon MP530. Can I fix?
Sounds like a carriage issue and unfortunately you can buy that printer new for less then it costs to get a new carriage put in
11/13/2017 1:50:38 AM • Canon PIXMA ... • Answered on Nov 13, 2017
7answers
Canon MP530 Makes Grinding Noise when printing starts
I had this same problem and called tech support. Instead of sending a new printer they had me
1 remove print Cartridges
2 remove print head
3 replace print head
4 replace print Cartridges
5 unplug power from the wall
This seemed to fix the problem.....for me anyway.....for now.
hope it helps
8/26/2016 11:48:32 AM • Canon PIXMA ... • Answered on Aug 26, 2016
What does the print head look like in the Canon MP530?
The print head is what's connected to the drive belt. It requires a lot of printer disassembly to get to. Check you tube for a video in how to change it.
7/26/2016 5:43:29 AM • Canon PIXMA ... • Answered on Jul 26, 2016
CODE U 052
Or you were wrong cartridge or print your car is not drivable, first check yourcartridges and they are positioned correctly, that they do not and are forced to the right place each.
5/29/2016 5:12:43 AM • Canon PIXMA ... • Answered on May 29, 2016
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
1,272 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
service error 5c10
  • Office Equipment & Supplies
