20 Most Recent Motorola Mobility MOTOMING A1200 Smartphone Questions & Answers
I had to clean my phone so I just switched off the phone, cleaned the phone and then switched on. As switching the phone a message was displayed that memory card has been locked and a password was needed to unlock. Please can you help me with password
Motorola... | Answered on Nov 15, 2016
Your in luck! www.cnn.cn you can get full housings and replacement hinge springs for this model phone. Im not sure which parts exactly are broken on yours, but you can get any of the case pieces from that web site. I personally have ordered from there before and have been satisfied.
As far as the repair manual, no, there are none available to consumers that im aware of.
Need anymore help let me know!
Motorola... | Answered on Jul 19, 2012
mobile format
Motorola... | Answered on Oct 13, 2011
With the help of the codes you can unlock your Motorola mobile, so get the unlock code for your Motorola mobile through this site www.theunlockspot.com/motorola-motoming-a1200/rs10wp9 , it has the step by step instructions and simple methods for getting the unlock code for your mobile from the network lock.........
Motorola... | Answered on Sep 09, 2011
Try this, go around the edge of the screen with a tooth brush. If small particles of dirt have lodged there it can cause the screen to get out of calibration. Get the brush in between the case and the screen. Hope that will fixya up.
Motorola... | Answered on Dec 09, 2010
If you can't hear, then it's the ringer or speaker problem, try with your headset to make sure it's working. If you can hear using your headset, you only need to replace the Speaker, the technician at the mobile repairing shop will fix it for you. Good luck. Thanks for using FixYa.
Motorola... | Answered on Jun 06, 2010
The a1200 has no format option, you need to flash it with a ROM or preferably a monster pack. You would use a program call RSD Lite for this. Check out www.modmymoto.com, they have it all there...
EJ
Motorola... | Answered on Apr 10, 2010
u need to change the flexible/ribbon cable running from ur main PCB to the flap. its available with me in case u require. the solution is 100% guaranteed.
Motorola... | Answered on Jan 31, 2010
there is problem in ur mike ..plz clean ur board with pcb board cleaner...
or
change the new mike
Motorola... | Answered on Oct 04, 2009
Go to contacts,then view,then shift to name and number ,.. you'll be able to see both name and number simultaneously.
Motorola... | Answered on Sep 22, 2009
Unless you've changed it, it is usually the last four digits of your phone number by default
Motorola... | Answered on Aug 28, 2009
how can i connect to the internet using my motoming a1200
Motorola... | Answered on Aug 18, 2009
Regarding with your problem, you better call your network provider for this issue, they can assist you and remotely unlock your phone.
Hope this helps.
micro
Motorola... | Answered on Jul 19, 2009
wht kind of software u need sir??
u need whole firmware ??
if so, then plz vist www.motorolafans.com their u'll get ech n everything needed for ur gr8 PDA.
http://www.motorolafans.com/forums/
right form modifying ur cellphone to abt thing u need..
thank u very uch sir.
if u feel my refernce is worth visiting then plz give me a vote/rating sir..!!
Motorola... | Answered on Jul 17, 2009
call to motorollacustomer care number they will let you no or try logging to motorolla website
You need to format your memory card.. Then you can set a new password..
Motorola... | Answered on Jul 11, 2009
your motoming A1200 mobile's unlock code is 1234 or security code is 000000
Motorola... | Answered on Apr 20, 2009
Motorola Mobility MOTOMING A1200 Smartphone Logo
41 questions posted
Top Motorola Mobility Computers & Internet Experts
Tom Chichester
JessicaChane2345
FiFo
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Mobility Computers & Internet
Most Popular Question
motorola a1200 flip damaged
  • Computers & Internet
