20 Most Recent
Dell E207WFP LCD Monitor Questions & Answers
Dell monitor is flickering
If you have another computer, try hooking to it and see if it flickers on it too.
If you hit Ctl-Alt-Delete and choose Task Manager, does the box flicker there?.
Adjust the monitor ratio in the Display Settings/Display/ Display Adapter Properties, Monitor Tab, see drop down (increase screen refresh ratio to higher number).
Box keeps popping up
you have to explain the issue in more detail. Boxes popping up on Windows PCs is normal.. they can be warnings, offer selection options, they can be information to your request, etc.
Red line on sceen?
I had a similar problem with my LCD screen TV, and to my dismay, my
warranty just ran out. A thin red line began to appear on the right side
of the screen, and since many online and expert sources pretty much say
replace the expensive LCD screen or get a professional to fix it (in
which I suspect to be a business plot to get people to go to pricey
experts), I decided to look for other possible alternatives.
Here is some tips/solutions I was given (and it worked! at least for me):
1) Turn off the LCD and unplug the power source and let it rest for 5-10
minutes. Turn it back on and see if it disappears or improve. (This is
the one I used.)
2) While turned off, try jiggling gently all chords connected to the TV
(cables, power chords, etc.); you could even try unplugging and
replugging the chords/cables. Turn the TV back on and see if the red
line disappeared or improve. (This is the one I heard worked for
others.)
If the above doesn't work then I'm afraid you do have a bad panel on
your screen and will need to call in the experts or get a new TV. I hope
this will help. Best Wishes.
Dell E207WFP Display Problem
check your system vga out put is working or not, conform this by connecting another monitor or connect monitor to another computer.
